[GeoNode-devel] groups permissions in 2.4
Simone Dalmasso simone.dalmasso at gmail.com
Tue May 5 02:20:29 PDT 2015
Glad you solved. But the correct way is to not use the admin to create
Groups but use the GeoNode section. http://localhost:8000/groups/
The admin can be used to modify existing data.
Regards
2015-05-05 11:18 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
> Hi I found the problem now:
> I was creating a group only  through the /admin/auth/group/ link. Then
> this group doesnt show up in the autocomple / GroupProfile.objects.all()
> Object.
> The good way to create a group that actually works is
> through /admin/groups/groupprofile/add/ . After doing that the group shows
> up in  /admin/auth/group/ too and can be granted permissions.
> Should this go into the docs?
> KInd regards and many thanks for your help and patience. Big up GeoNode!
> _____________________________________
> *A P L I K @ T E . E U <http://www.aplikate.eu/>*
> Linux, GIS and database developer team
> Wittmannsdorfer Str. 4
> 12053 Berlin
> Germany / Allemagne
> Tel.: +49 (0) 30 28 45 40 71
> Mobil: +49 (0) 163 681 77 34
> Fax: +49 (0)30 / 48 49 81 286
> 2015-05-05 11:11 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Ok so the problem seems to be that you have no groups.
>> How did you create the groups? The correct way is to create them through
>> the Groups section in GeoNode.
>> 2015-05-05 11:08 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>> Hi Simone, GroupProfile.objects.all() appears to be empty, this is my
>>> output:
>>> >>> from geonode.groups.models import GroupProfile
>>> 12053 Berlin
>>> Germany / Allemagne
>>> 2015-05-05 10:57 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Rainer,
>>>> I can't replicate the behavior, I create a group in the group tab and
>>>> then it's available in the autocomplete. The function that is handling that
>>>> is this one
>>>> https://github.com/GeoNode/geonode/blob/master/geonode/views.py#L70 and
>>>> it simply does a GroupProfile.objects.filter.
>>>> Can you try to run these commands:
>>>> $ geonode shell
>>>> and see whether it's correctly returning your groups.
>>>> 2015-05-05 10:26 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>>> Hi Simone,
>>>>> I installed 2.4.0+beta25 from the testing ppa and still I cant get
>>>>> any results from the groups autocomplete field. The response for the ajax
>>>>> request is {"count": 0, "users": [], "groups": []}
>>>>> I added an '*' to the  the ALLOWED_HOSTS in local_settings.py, if
>>>>> thats of any importance for above problem.
>>>>> 12053 Berlin
>>>>> Germany / Allemagne
>>>>> 2015-05-04 14:31 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>>>> super thanks! I'll just use a fresh vagrant vm
>>>>>> 12053 Berlin
>>>>>> Germany / Allemagne
>>>>>> 2015-05-04 14:25 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com
>>>>>>> Yes will overwrite the current one. I suggest you to use a new
>>>>>>> Ubuntu though. Because until we release the final the upgrade between
>>>>>>> versions may not be smooth.
>>>>>>> Il lunedì 4 maggio 2015, Rainer Lissewski <r.lissewski at aplikate.eu>
>>>>>>> ha scritto:
>>>>>>>> oh wow! will this be available via ppa directly?
>>>>>>>> 12053 Berlin
>>>>>>>> Germany / Allemagne
>>>>>>>> 2015-05-04 13:35 GMT+02:00 Simone Dalmasso <
>>>>>>>>> weird, anyway I'm going to release e new beta today, you can
>>>>>>>>> install it and should solve. If you install it within 4 hours you'll get a
>>>>>>>>> faster and better geonode.
>>>>>>>>> 2015-05-04 13:33 GMT+02:00 Rainer Lissewski <
>>>>>>>>>> exactly, the autocomplete isnt working
>>>>>>>>>> 12053 Berlin
>>>>>>>>>> Germany / Allemagne
>>>>>>>>>> 2015-05-04 13:29 GMT+02:00 Simone Dalmasso <
>>>>>>>>>>> On my 2.4 after I create a group in the groups section then it
>>>>>>>>>>> will appear in the autocomplete. Is it not working for you?
>>>>>>>>>>> 2015-05-04 13:25 GMT+02:00 Rainer Lissewski <
>>>>>>>>>>>> Ok I installed on trusty 14.04 and it is  2.4.0+beta24 (just
>>>>>>>>>>>> checked via aptitude).
>>>>>>>>>>>> Still if I try to set groups permissions as in screenshot
>>>>>>>>>>>> below, I can't choose any existing group..
>>>>>>>>>>>> [image: Inline-Bild 1]
>>>>>>>>>>>> 12053 Berlin
>>>>>>>>>>>> Germany / Allemagne
>>>>>>>>>>>> 2015-05-04 13:19 GMT+02:00 Simone Dalmasso <
>>>>>>>>>>>>> Hi yes, is implemented and available in the
>>>>>>>>>>>>> ppa:geonode/testing. Beware that geonode 2.4 is available only on ubuntu
>>>>>>>>>>>>> 14.04.
>>>>>>>>>>>>> 2015-05-04 13:15 GMT+02:00 Rainer Lissewski <
>>>>>>>>>>>>> rainerlissewski at gmail.com>:
>>>>>>>>>>>>>> Hi is the full groups permissions system implemented in 2.4
>>>>>>>>>>>>>> as available in the ubuntu *ppa:geonode/testing *repo?
>>>>>>>>>>>>>>  I saw  https://github.com/GeoNode/geonode/pull/1406 and it
>>>>>>>>>>>>>> appears to be merged still on my 2.4 installation from abovementioned ppa
>>>>>>>>>>>>>> the functionality isnt there..
>>>>>>>>>>>>>> Kind regards
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>>>>>>>>>> Simone
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/f5712965/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/f5712965/attachment-0001.png>
More information about the geonode-devel mailing list
