[GeoNode-devel] How can I protect a WMS service by password? geonode 2.4b25
Jeffrey Johnson ortelius at gmail.com
Wed May 6 02:28:44 PDT 2015
Note that a more robust permissions system on the geoserver side is
very high on our priority list. We are looking at the geofence plugin
from GeoSolutions
http://www.slideshare.net/geosolutions/advanced-geoserver-security-with-geofence
and looking for some organizational funding to make that happen.
(To the wider community) If you or your agency is interested in this
kind of thing, lets all figure out how to pool our resources to make
it happen.
Jeff
On Wed, May 6, 2015 at 5:20 AM, Rainer Lissewski
<rainerlissewski at gmail.com> wrote:
> Yes I fully understand that.Thanks for clarifying here, so that also other
> people understand the concept. ;-)
> Kind rgrds
> Am 06.05.2015 um 10:05 schrieb Simone Dalmasso:
> Rainer, a GeoNode layer is by definition a layer on geoserver which means
> OGS services. Geoserver will respect the view permissions on the layer but
> it will always be a WMS layer.
> 2015-05-06 9:54 GMT+02:00 Rainer Lissewski <rainerlissewski at gmail.com>:
>> Simone,
>> I mean I have a layer in geonode and serve it out as a WMS.
>> The first question below is solved, the permissions work also for the WMS.
>> Second question: Is there a way cancel the publishing of a layer as WMS,
>> apart from taking away all permissions from a layer?
>> Kind regards
>> R
>> Am 06.05.2015 um 08:40 schrieb Simone Dalmasso:
>> Rainer, by publishing a WMS you mean that you uploaded a layer or you
>> created a remote service?
>> 2015-05-05 19:21 GMT+02:00 Rainer Lissewski <rainerlissewski at gmail.com>:
>>> Hi I was publishing a WMS from the geonode GUI.
>>> In spite the map being limited by permissions  to only be accessed by me,
>>> I could see and open the WMS in QGIS without password or username.
>>> Also, how can I cancel the publishing as WMS?
>>> Is this a bug or am I doing something wrong?
>>> Best
>>> R
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>> Simone
> Simone
More information about the geonode-devel mailing list
