[GeoNode-devel] Group invite via email --> internal server error ( /groups/group/test/invite/)
Rainer Lissewski rainerlissewski at gmail.com
Wed May 6 02:31:43 PDT 2015
Same error occurs when inviting a single user via /account/invite_user/
Am 05.05.2015 um 14:40 schrieb Simone Dalmasso:
> Rainer, this is indeed a bug due to this,
> https://github.com/GeoNode/geonode/blob/master/geonode/groups/models.py#L223.
> We will have to do a deep notifications refactoring (which is why that
> method is commented) in the meantime you can try to uncomment that
> method. Please report here how it goes.
> 2015-05-05 12:40 GMT+02:00 Rainer Lissewski <rainerlissewski at gmail.com
> <mailto:rainerlissewski at gmail.com>>:
>     Hi on trying to invite group members via email, I get an internal
>     server error from /groups/group/test/invite/
>     Apache log:
>     /[Tue May 05 05:21:11.374979 2015] [:error] [pid 20113:tid
>     140121475692288]   File
>     "/usr/local/lib/python2.7/dist-packages/geonode/groups/models.py",
>     line 167, in invite/
>     /[Tue May 05 05:21:11.375008 2015] [:error] [pid 20113:tid
>     140121475692288] invitation.send(from_user)/
>     /[Tue May 05 05:21:11.375079 2015] [:error] [pid 20113:tid
>     140121475692288] AttributeError: 'GroupInvitation' object has no
>     attribute 'send'/
>     /[Tue May 05 05:21:11.401051 2015] [:error] [pid 20113:tid
>     140121475692288] [remote 10.0.2.2:16025 <http://10.0.2.2:16025/>]
>     mod_wsgi (pid=20113): Exception occurred processing WSGI script
>     '/var/www/geonode/wsgi/geonode.wsgi'./
>     /[Tue May 05 05:21:11.401079 2015] [:error] [pid 20113:tid
>     Traceback (most recent call last):/
>     /[Tue May 05 05:21:11.401101 2015] [:error] [pid 20113:tid
>       File
>     "/usr/lib/python2.7/dist-packages/django/core/handlers/wsgi.py",
>     line 206, in __call__/
>     /[Tue May 05 05:21:11.401129 2015] [:error] [pid 20113:tid
>         response = self.get_response(request)/
>     /[Tue May 05 05:21:11.401147 2015] [:error] [pid 20113:tid
>       File
>     "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py",
>     line 194, in get_response/
>     /[Tue May 05 05:21:11.401174 2015] [:error] [pid 20113:tid
>         response = self.handle_uncaught_exception(request, resolver,
>     sys.exc_info())/
>     /[Tue May 05 05:21:11.401191 2015] [:error] [pid 20113:tid
>       File
>     line 236, in handle_uncaught_exception/
>     /[Tue May 05 05:21:11.401214 2015] [:error] [pid 20113:tid
>         return callback(request, **param_dict)/
>     /[Tue May 05 05:21:11.401231 2015] [:error] [pid 20113:tid
>       File
>     "/usr/lib/python2.7/dist-packages/django/utils/decorators.py",
>     line 99, in _wrapped_view/
>     /[Tue May 05 05:21:11.401264 2015] [:error] [pid 20113:tid
>         response = view_func(request, *args, **kwargs)/
>     /[Tue May 05 05:21:11.401297 2015] [:error] [pid 20113:tid
>       File
>     "/usr/lib/python2.7/dist-packages/django/views/defaults.py", line
>     46, in server_error/
>     /[Tue May 05 05:21:11.401322 2015] [:error] [pid 20113:tid
>         return http.HttpResponseServerError(template.render(Context({})))/
>     /[Tue May 05 05:21:11.401381 2015] [:error] [pid 20113:tid
>       File "/usr/lib/python2.7/dist-packages/django/template/base.py",
>     line 140, in render/
>     /[Tue May 05 05:21:11.401406 2015] [:error] [pid 20113:tid
>         return self._render(context)/
>     /[Tue May 05 05:21:11.401422 2015] [:error] [pid 20113:tid
>     line 134, in _render/
>     /[Tue May 05 05:21:11.401444 2015] [:error] [pid 20113:tid
>         return self.nodelist.render(context)/
>     /[Tue May 05 05:21:11.401463 2015] [:error] [pid 20113:tid
>     line 840, in render/
>     /[Tue May 05 05:21:11.401486 2015] [:error] [pid 20113:tid
>         bit = self.render_node(node, context)/
>     /[Tue May 05 05:21:11.401503 2015] [:error] [pid 20113:tid
>     line 854, in render_node/
>     /[Tue May 05 05:21:11.401525 2015] [:error] [pid 20113:tid
>         return node.render(context)/
>     /[Tue May 05 05:21:11.401541 2015] [:error] [pid 20113:tid
>       File
>     "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py",
>     line 53, in render/
>     /[Tue May 05 05:21:11.401586 2015] [:error] [pid 20113:tid
>         result = self.nodelist.render(context)/
>     /[Tue May 05 05:21:11.401604 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401627 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401643 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401665 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401697 2015] [:error] [pid 20113:tid
>       File
>     line 155, in render/
>     /[Tue May 05 05:21:11.401720 2015] [:error] [pid 20113:tid
>         return self.render_template(self.template, context)/
>     /[Tue May 05 05:21:11.401737 2015] [:error] [pid 20113:tid
>       File
>     line 137, in render_template/
>     /[Tue May 05 05:21:11.401759 2015] [:error] [pid 20113:tid
>         output = template.render(context)/
>     /[Tue May 05 05:21:11.401778 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401800 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401817 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401838 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401855 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401877 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401906 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401929 2015] [:error] [pid 20113:tid
>     /[Tue May 05 05:21:11.401946 2015] [:error] [pid 20113:tid
>       File
>     "/usr/lib/python2.7/dist-packages/announcements/templatetags/announcements_tags.py",
>     line 24, in render/
>     /[Tue May 05 05:21:11.401969 2015] [:error] [pid 20113:tid
>         request = context["request"]/
>     /[Tue May 05 05:21:11.401994 2015] [:error] [pid 20113:tid
>       File
>     "/usr/lib/python2.7/dist-packages/django/template/context.py",
>     line 56, in __getitem__/
>     /[Tue May 05 05:21:11.402022 2015] [:error] [pid 20113:tid
>         raise KeyError(key)/
>     /[Tue May 05 05:21:11.402043 2015] [:error] [pid 20113:tid
>     KeyError: 'request'/
>     /[Tue May 05 05:27:08.763694 2015] [:error] [pid 20114:tid
>     140121475692288] Internal Server Error: /groups/group/test/invite//
>     /[Tue May 05 05:27:08.763800 2015] [:error] [pid 20114:tid
>     140121475692288] Traceback (most recent call last):/
>     /[Tue May 05 05:27:08.763872 2015] [:error] [pid 20114:tid
>     line 112, in get_response/
>     /[Tue May 05 05:27:08.763902 2015] [:error] [pid 20114:tid
>     140121475692288] response = wrapped_callback(request,
>     *callback_args, **callback_kwargs)/
>     /[Tue May 05 05:27:08.763956 2015] [:error] [pid 20114:tid
>     "/usr/lib/python2.7/dist-packages/django/views/decorators/http.py", line
>     41, in inner/
>     /[Tue May 05 05:27:08.763985 2015] [:error] [pid 20114:tid
>     140121475692288] return func(request, *args, **kwargs)/
>     /[Tue May 05 05:27:08.764012 2015] [:error] [pid 20114:tid
>     "/usr/local/lib/python2.7/dist-packages/geonode/groups/views.py",
>     line 182, in group_invite/
>     /[Tue May 05 05:27:08.764039 2015] [:error] [pid 20114:tid
>     140121475692288] role=form.cleaned_data["invite_role"])/
>     /[Tue May 05 05:27:08.764067 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.764131 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.764158 2015] [:error] [pid 20114:tid
>     attribute 'send'/
>     /[Tue May 05 05:27:08.791043 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx] mod_wsgi (pid=20114):
>     /[Tue May 05 05:27:08.791074 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx] Traceback (most recent
>     call last):/
>     /[Tue May 05 05:27:08.791100 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx]   File
>     /[Tue May 05 05:27:08.791179 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx]     response =
>     /[Tue May 05 05:27:08.791212 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.791238 2015] [:error] [pid 20114:tid
>     self.handle_uncaught_exception(request, resolver, sys.exc_info())/
>     /[Tue May 05 05:27:08.791266 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.791290 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx]     return
>     /[Tue May 05 05:27:08.791310 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.791376 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.791396 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.791452 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.791472 2015] [:error] [pid 20114:tid
>     "/usr/lib/python2.7/dist-packages/django/template/base.py", line
>     140, in render/
>     /[Tue May 05 05:27:08.791708 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.791730 2015] [:error] [pid 20114:tid
>     134, in _render/
>     /[Tue May 05 05:27:08.791755 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.791774 2015] [:error] [pid 20114:tid
>     840, in render/
>     /[Tue May 05 05:27:08.791797 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx]     bit =
>     /[Tue May 05 05:27:08.791821 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.791848 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.791869 2015] [:error] [pid 20114:tid
>     line 53, in render/
>     /[Tue May 05 05:27:08.791948 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx]     result =
>     /[Tue May 05 05:27:08.791968 2015] [:error] [pid 20114:tid
>     840, in render/
>     /[Tue May 05 05:27:08.791992 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792009 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792031 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792047 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792069 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792086 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792112 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx]     output =
>     /[Tue May 05 05:27:08.792129 2015] [:error] [pid 20114:tid
>     140, in render/
>     /[Tue May 05 05:27:08.792151 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792168 2015] [:error] [pid 20114:tid
>     134, in _render/
>     /[Tue May 05 05:27:08.792188 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792205 2015] [:error] [pid 20114:tid
>     840, in render/
>     /[Tue May 05 05:27:08.792226 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792243 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792264 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792281 2015] [:error] [pid 20114:tid
>     line 24, in render/
>     /[Tue May 05 05:27:08.792329 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx]     request =
>     context["request"]/
>     /[Tue May 05 05:27:08.792361 2015] [:error] [pid 20114:tid
>     /[Tue May 05 05:27:08.792478 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx]     raise KeyError(key)/
>     /[Tue May 05 05:27:08.792503 2015] [:error] [pid 20114:tid
>     140121475692288] [remote xx.x.x.x:xxxxx] KeyError: 'request'/
>     _______________________________________________
>     geonode-devel mailing list
>     geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150506/792a9939/attachment-0001.html>
More information about the geonode-devel mailing list
