[GeoNode-devel] Problem with saving styles "there was an error saving the style back to the server" on 2.4b25 on trusty / Vagrant VM
Ariel Nunez ingenieroariel at gmail.com
Tue May 12 08:05:12 PDT 2015
The fix is:
sudo chown -R /var/www/geonode/uploaded www-data:www-data
On Tue, May 12, 2015 at 10:01 AM, Rainer Lissewski <
rainerlissewski at gmail.com> wrote:
> Hi I get an  "there was an error saving the style back to the server" msg
> on trying to save styles. Eventually it (partially works, but the error
> comes up very frequent. It is a layer that has been added from another
> postgis datastore along the lines  of
> http://geonode.readthedocs.org/en/latest/tutorials/admin/commands.html#updatelayers
> Stacktrace:
> [Tue May 12 09:52:27.968168 2015] [:error] [pid 30225:tid 139984521770752]
> Internal Server Error: /gs/rest/styles/HVTgeom2_9b5c1e56.xml
> [Tue May 12 09:52:27.968289 2015] [:error] [pid 30225:tid 139984521770752]
> Traceback (most recent call last):
> [Tue May 12 09:52:27.968356 2015] [:error] [pid 30225:tid 139984521770752]
>   File "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py",
> line 112, in get_response
> [Tue May 12 09:52:27.968386 2015] [:error] [pid 30225:tid 139984521770752]
>     response = wrapped_callback(request, *callback_args, **callback_kwargs)
> [Tue May 12 09:52:27.968475 2015] [:error] [pid 30225:tid 139984521770752]
>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/views.py",
> line 339, in geoserver_rest_proxy
> [Tue May 12 09:52:27.968545 2015] [:error] [pid 30225:tid 139984521770752]
>     style_update(request, url)
> [Tue May 12 09:52:27.968573 2015] [:error] [pid 30225:tid 139984521770752]
>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
> 1481, in style_update
> [Tue May 12 09:52:27.968715 2015] [:error] [pid 30225:tid 139984521770752]
>     layer.save()
> [Tue May 12 09:52:27.968732 2015] [:error] [pid 30225:tid 139984521770752]
>   File "/usr/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py",
> line 90, in save
> [Tue May 12 09:52:27.968742 2015] [:error] [pid 30225:tid 139984521770752]
>     return super(PolymorphicModel, self).save(*args, **kwargs)
> [Tue May 12 09:52:27.968751 2015] [:error] [pid 30225:tid 139984521770752]
>   File "/usr/lib/python2.7/dist-packages/django/db/models/base.py", line
> 545, in save
> [Tue May 12 09:52:27.968761 2015] [:error] [pid 30225:tid 139984521770752]
>     force_update=force_update, update_fields=update_fields)
> [Tue May 12 09:52:27.968770 2015] [:error] [pid 30225:tid 139984521770752]
> 582, in save_base
> [Tue May 12 09:52:27.968779 2015] [:error] [pid 30225:tid 139984521770752]
>     update_fields=update_fields, raw=raw, using=using)
> [Tue May 12 09:52:27.968801 2015] [:error] [pid 30225:tid 139984521770752]
>   File "/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
> line 185, in send
> [Tue May 12 09:52:27.968839 2015] [:error] [pid 30225:tid 139984521770752]
>     response = receiver(signal=self, sender=sender, **named)
> [Tue May 12 09:52:27.968865 2015] [:error] [pid 30225:tid 139984521770752]
>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py", line
> 390, in geoserver_post_save
> [Tue May 12 09:52:27.968931 2015] [:error] [pid 30225:tid 139984521770752]
>     create_thumbnail(instance, thumbnail_remote_url, thumbnail_create_url,
> ogc_client=http_client)
> [Tue May 12 09:52:27.968959 2015] [:error] [pid 30225:tid 139984521770752]
>   File "/usr/local/lib/python2.7/dist-packages/geonode/layers/utils.py",
> line 592, in create_thumbnail
> [Tue May 12 09:52:27.969019 2015] [:error] [pid 30225:tid 139984521770752]
>     instance.save_thumbnail(filename, image=image)
> [Tue May 12 09:52:27.969048 2015] [:error] [pid 30225:tid 139984521770752]
>   File "/usr/local/lib/python2.7/dist-packages/geonode/base/models.py",
> line 559, in save_thumbnail
> [Tue May 12 09:52:27.969075 2015] [:error] [pid 30225:tid 139984521770752]
>     with open(os.path.join(upload_path, filename), 'w') as f:
> [Tue May 12 09:52:27.969106 2015] [:error] [pid 30225:tid 139984521770752]
> IOError: [Errno 13] Permission denied:
> u'/var/www/geonode/uploaded/thumbs/layer-efe85a37-9a78-41ce-9692-cd0920486afd-thumb.png'
> [Tue May 12 09:52:27.988412 2015] [:error] [pid 30225:tid 139984521770752]
> [remote 10.0.2.2:15799] mod_wsgi (pid=30225): Exception occurred
> processing WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150512/25de2467/attachment.html>
More information about the geonode-devel mailing list
