[GeoNode-devel] Feature proposals 20150513
Jeffrey Johnson ortelius at gmail.com
Wed May 13 13:16:48 PDT 2015
You usually need to work with an existing core committer until you
have made several commits.
Why dont you look at one of the GNIPs I've worked on (i.e.
https://github.com/GeoNode/geonode/issues/1915) and start a google doc
with this info, share it with me and I can work on it with you.
Cheers!
Jeff
On Wed, May 13, 2015 at 1:15 PM, Rainer Lissewski
<rainerlissewski at gmail.com> wrote:
> Hi Jeffrey, thanks for your mail.
> Just read that only commiters can file a GNIP.
> If you provide me commiter status I will happy to do so.
> github.com/rajanski
> And yes I just discovered HeronMC and find it really very cool and complete
> in terms of GIS functionality.
> Kind regards
> Rainer
> Am 13.05.2015 um 22:02 schrieb Jeffrey Johnson:
>> Yes, this should be possible. Look at things like
>> https://github.com/ROGUE-JCTD/django-maploom that setup an alternative
>> mapping client with the necessary static media etc.
>> I would file a GNIP for this with a core dev and talk about an
>> implementation plan together. Happy to help.
>> HeronMC looks pretty cool!
>> @bartvde any thoughts on this one?
>> On Wed, May 13, 2015 at 9:07 AM, Rainer Lissewski
>>> Geoexplorer: Extend query tool to enable export of query results as seen
>>> in
>>> http://lib.heron-mc.org/heron/latest/examples/querybuilder/ (Heron
>>> Mapclient, based on GeoEXT), which leads to:
>>> Use HeronMC as MapClient in geonode? Is that possible?
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
