[GeoNode-devel] Updating layer title, publishing date from remote script?
Simone Dalmasso simone.dalmasso at gmail.com
Wed Nov 4 23:41:40 PST 2015
Hi Bruce,
good points, the updatelayers command is not updating the title, this is
the code called
https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/helpers.py#L353
we
need some refactor here to make it respect all the changes. The title is
updated if changed from the layer's metadata page though.
About the maplayers, there's no code that updates the layer_params and
would be good to enhance the updatemaplayer_ip command
https://github.com/GeoNode/geonode/blob/master/geonode/maps/management/commands/updatemaplayerip.py,
to do all the necessary tasks so to be a more generic updatemaplayer.
If you can provide PRs on that would be awesome, can you fill a couple of
tickets in github? there's already one for updatelayers
https://github.com/GeoNode/geonode/issues/2177.
2015-11-04 23:57 GMT+01:00 Bruce Crevensten <becrevensten at alaska.edu>:
> Hi, I'm working on an application that uses GeoNode to manage geospatial
> information, and I need to set up a routine that replaces layer content on
> a daily basis.
> I can use the manage.py utility to update the underlying data source,
> apparently with no problems.  I forked & made a small change to the
> layers/management/commands/importlayers.py & layers/utils.py script to
> allow an explicit layer --name to be provided so we have a constant slug to
> use for updating the layer (otherwise, we get new layers for every changed
> title):
> https://github.com/ua-snap/geonode/pull/7/files
> (I'll work that into a candidate PR once I have all the functionality I
> want working).
> I'd also like to be able to change the layer's title (both in the catalog
> of layers as well as on any layers being used in maps) and publishing date
> to reflect the changing date of the data.  From what I can tell, the code
> isn't updating the title at all, and I'm not clear if this is expected
> behavior (when updating an existing layer & overwrite = true, the title
> isn't updated) or if perhaps I've unwittingly broken something.
> Related, I'm unclear as to how to change the title of a mapLayer.  Doesn't
> look like the API currently supports this, or that there are any existing
> management tools to do it.  I know the mapLayer takes its title from the
> title of the Layer upon creation, but subsequent updating seems to be done
> via GeoExplorer.  Any suggestions on how I may want to approach this?
> Thanks!
> *Bruce Crevensten*
> *Senior Software Engineer*
> (SNAP) Scenarios Network for Alaska & Arctic Planning
> www.snap.uaf.edu
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151105/fbb2e988/attachment.html>
More information about the geonode-devel mailing list
