[GeoNode-devel] Table Join - Field Format Conversion
Jeffrey Johnson ortelius at gmail.com
Mon Nov 30 13:17:04 PST 2015
Yes, this is the correct branch. I keep trying to make time to
continue working on it, but havent been able to so far. I will likely
have more time in the coming weeks before the holidays.
Paolo, do you want to setup a time to discuss and review what remains
to be done?
On Mon, Nov 30, 2015 at 11:47 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi Jeff
> As you know, I will need start using this stuff in GeoNode.
> Can you confirm me that this is the latest version of the code?
> https://github.com/jj0hns0n/geonode/tree/table-join
> thanks
> p
> On Mon, Feb 23, 2015 at 4:33 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
>> Hi Gents,
>> As mentioned in a previous post and in GNIP #1915, I've been working
>> on adding a new 'datatables' contrib module for GeoNode that allows
>> for uploading of CSV or other delimited files and loading these into
>> PostgreSQL and joining a existing geometry to them. You can see the
>> implementation here
>> https://github.com/jj0hns0n/geonode/compare/table-join?expand=1 ...
>> Everything is mostly working and functional at an API level. You can
>> see the test setup we are using in tabular-api/code/tabular_test.py
>> (this will get converted into a more complete integration test suite).
>> The largest issue we have run into in our testing is field type
>> mismatches. The simplest case is an int field in either the table or
>> the layer and a string field in the other. There are also issues with
>> the field being specified with leading zeroes or other characters in
>> one of the 2 join components and not in the other. The folks at
>> harvard have found other instances where they need to actually join
>> the contents of 2 fields together before joining.
>> Some tickets in my own fork for background/reference.
>> https://github.com/jj0hns0n/geonode/issues/34
>> https://github.com/jj0hns0n/geonode/issues/30
>> https://github.com/jj0hns0n/geonode/issues/40
>> https://github.com/jj0hns0n/geonode/issues/50
>> https://github.com/jj0hns0n/geonode/issues/49 (the ticket Im dealing
>> with _right now_)
>> Raman (@raprasad) and I have discussed several options for dealing
>> with this kind of problem and we decided to add a class
>> JoinTargetFormatType that could store information necessary to do
>> these kinds of conversions. You can see that class here
>> https://github.com/jj0hns0n/geonode/blob/table-join/geonode/contrib/datatables/models.py#L51
>> which is used in the JoinTarget class here
>> https://github.com/jj0hns0n/geonode/blob/table-join/geonode/contrib/datatables/models.py#L71
>> ... The basic idea is that you could have a set of pre-defined
>> transformation functions or include some regex or a python function to
>> do the conversion. None of this is hooked up yet, but thats the basic
>> idea.
>> So, we wanted to consult with all of you to see if anyone had any
>> ideas about how best to hook this kind of thing up ... or perhaps some
>> words of caution about how NOT to do this.
>> Happy to discuss further if anyone has any questions or is unclear on
>> what we are trying to do.
>> Thanks in advance,
>> Jeff
>> To unsubscribe from this group and stop receiving emails from it, send an email to geonode-dev+unsubscribe at boundlessgeo.com.
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
More information about the geonode-devel mailing list
