[GeoNode-devel] bing api request denied
Simone Dalmasso simone.dalmasso at gmail.com
Wed Oct 7 07:06:13 PDT 2015
Paolo that's right :(
2015-10-07 15:57 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> Thanks to both
> for system in productions containing existing maps I think the only way is
> to follow Bart's suggestion or running a script able to remove the Bing map
> baselayer from any existing map.
> cheers
> p
> On Wed, Oct 7, 2015 at 3:51 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Thanks Bart,
>> then is good to keep it disabled by default and add instructions on how
>> to properly add it.
>> 2015-10-07 15:50 GMT+02:00 Bart van den Eijnden <bartvde at boundlessgeo.com
>>> Ideally you would have requested your own API key for your site on
>>> https://www.bingmapsportal.com
>>> And then configure the gxp Bing source with the apiKey property / config.
>>> Best regards,
>>> Bart
>>> Front End Software Engineer | Boundless <http://boundlessgeo.com/>
>>> 1-877-673-6436 <917-460-7207>
>>> @boundlessgeo <http://twitter.com/boundlessgeo/>
>>> <http://boundlessgeo.com>
>>> On 07 Oct 2015, at 15:41, Simone Dalmasso <simone.dalmasso at gmail.com>
>>> wrote:
>>> Dears,
>>> from yesterday the bing maps api that are used by default in every
>>> GeoNode map are not working anymore due to a request denied. The effect is
>>> that every map in GeoNode cannot be zoomed properly anymore.
>>> While we try to figure out what is the cause of this we suggest a quick
>>> fix,
>>> open your GeoNode settings  (/etc/geonode/local_settings.py for a
>>> standard apt-get installation) and comment the following lines like we
>>> already did on master
>>> https://github.com/GeoNode/geonode/commit/f2707e64e78931b31a06016a3e04f1ba76021b66 then
>>> restart the web server.
>>> We appreciate any comment and feedback.
>>> Simone
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>> Simone
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151007/c73aa881/attachment.html>
More information about the geonode-devel mailing list
