[GeoNode-devel] Doubt in GeoNode's installation
Bárbara Ferreira arabrab.geo at gmail.com
Fri Oct 9 19:13:38 PDT 2015
Hi, Jeffrey.
I have done steps 1 and 2 of the quick installation of GeoNode (attached)
After this I entered the "http: // localhost: 8000" but does not work
After these steps (1 and 2), I do not know what to do:
I do not know if I did right to access "http: // localhost: 8000" after the
steps (1 and 2).
Or should I install the administrator or developer after the steps (1 and
2)?
Em 09/10/2015 22:28, "Jeffrey Johnson" <ortelius at gmail.com> escreveu:
> Did you see any output when you ran sudo apt-get install geonode? If
> so, what did it say? If not, what does it say when you try that
> command again?
> On Fri, Oct 9, 2015 at 4:51 PM, Bárbara Ferreira <arabrab.geo at gmail.com>
> wrote:
> > Hi,
> > I installed GeoNode using the Quick Start (Get Started Now) tutorial for
> > Ubuntu 14.4.
> > After that I tried to access the GeoNode through this link:
> > http://localhost:8000
> > ... And nothing happens.
> > I don't know how to continue ...
> > I did this "simple" installation (Quick Start) of GeoNode, but for my
> > project I need administrator or developer installation (in Ubuntu 14.04).
> > What would be the next step? Administrator or developer tutorial. In both
> > case, in which step I must continue?
> > Thanks.
> > Regards
> > Bárbara F
> > erreira
> > geonode-devel mailing list
> > geonode-devel at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151009/fbc586c0/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151009/fbc586c0/attachment-0001.jpeg>
More information about the geonode-devel mailing list
