[GeoNode-devel] Doubt in GeoNode's installation
Jeffrey Johnson ortelius at gmail.com
Fri Oct 9 19:41:04 PDT 2015
Ha, please check on just http://localhost not on port 8000
On Fri, Oct 9, 2015 at 7:13 PM, Bárbara Ferreira <arabrab.geo at gmail.com> wrote:
> Hi, Jeffrey.
> I have done steps 1 and 2 of the quick installation of GeoNode (attached)
> After this I entered the "http: // localhost: 8000" but does not work
> After these steps (1 and 2), I do not know what to do:
> I do not know if I did right to access "http: // localhost: 8000" after the
> steps (1 and 2).
> Or should I install the administrator or developer after the steps (1 and
> 2)?
> Em 09/10/2015 22:28, "Jeffrey Johnson" <ortelius at gmail.com> escreveu:
>> Did you see any output when you ran sudo apt-get install geonode? If
>> so, what did it say? If not, what does it say when you try that
>> command again?
>> On Fri, Oct 9, 2015 at 4:51 PM, Bárbara Ferreira <arabrab.geo at gmail.com>
>> wrote:
>> > Hi,
>> > I installed GeoNode using the Quick Start (Get Started Now) tutorial for
>> > Ubuntu 14.4.
>> > After that I tried to access the GeoNode through this link:
>> > http://localhost:8000
>> > ... And nothing happens.
>> > I don't know how to continue ...
>> > I did this "simple" installation (Quick Start) of GeoNode, but for my
>> > project I need administrator or developer installation (in Ubuntu
>> > 14.04).
>> > What would be the next step? Administrator or developer tutorial. In
>> > both
>> > case, in which step I must continue?
>> > Thanks.
>> > Regards
>> > Bárbara F
>> > erreira
>> > _______________________________________________
>> > geonode-devel mailing list
>> > geonode-devel at lists.osgeo.org
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
