[GeoNode-devel] [GeoNode-users] updatelayers not working: NoneType object has no attribute find
Jeffrey Johnson ortelius at gmail.com
Thu Oct 29 08:00:13 PDT 2015
Lets keep this on the list. Ill update the ticket and see if the
GeoSolutions guys have any ideas since they have been working on both
gsconfig and the imagemosaic plugin.
Jeff
On Thu, Oct 29, 2015 at 5:00 AM, Florian Hoedt <florian.hoedt at hs-owl.de> wrote:
> Hello Jeffrey,
> I tried to reopen the ticket but it seems like I am not allowed to do it (or I just do not know exactly what to click).
> Nevertheless here is the stacktrace:
> https://gist.github.com/gannebamm/1e1cd8442f90769d4c31
> The Layer is an imagemosaic datastore with the geoserver raster style as default style.
> mit freundlichen Grüßen
> Florian Hoedt
> B.Sc. Florian Hoedt
> Hochschule Ostwestfalen-Lippe / Campus Höxter
> FB 9 Landschaftsarchitektur und Umweltplanung
> An der Wilhelmshöhe 44
> 37671 Höxter
> Tel.: 05271-687-7478
> E-Mail: florian.hoedt at hs-owl.de
> www.hs-owl.de/fb9
> -----Ursprüngliche Nachricht-----
> Von: Jeffrey Johnson [mailto:ortelius at gmail.com]
> Gesendet: Montag, 26. Oktober 2015 17:34
> An: Florian Hoedt
> Cc: geonode-users at lists.osgeo.org; geonode-devel at lists.osgeo.org
> Betreff: Re: [GeoNode-users] updatelayers not working: NoneType object has no attribute find
> Florian,
> Can you add your stack trace to the ticket and re-open?
> Jeff
> On Mon, Oct 26, 2015 at 2:44 AM, Florian Hoedt <florian.hoedt at hs-owl.de> wrote:
>> Hello List,
>> Seems like this error still is present:
>> https://github.com/GeoNode/geonode/issues/869
>> I have created and deleted a lot of datastores in GeoServer (still learning) and after beeing happy with my aerials tried to:
>> sudo geonode updatelayers --skip-geonode-registered
>> which gave me:
>> Traceback (most recent call last):
>>   File "/usr/bin/django-admin", line 5, in <module>
>>     management.execute_from_command_line()
>>   File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 399, in execute_from_command_line
>>     utility.execute()
>>   File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 392, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>   File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py", line 242, in run_from_argv
>>     self.execute(*args, **options.__dict__)
>>   File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py", line 285, in execute
>>     output = self.handle(*args, **options)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py", line 108, in handle
>>     remove_deleted=remove_deleted)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line 458, in gs_slurp
>>     "bbox_y1": Decimal(resource.latlon_bbox[3])
>>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line 154, in get_or_create
>>     return self.get_queryset().get_or_create(**kwargs)
>>   File "/usr/local/lib/python2.7/dist-packages/modeltranslation/manager.py", line 341, in get_or_create
>>     return super(MultilingualQuerySet, self).get_or_create(**kwargs)
>>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 383, in get_or_create
>>     obj.save(force_insert=True, using=self.db)
>>   File "/usr/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py", line 90, in save
>>     return super(PolymorphicModel, self).save(*args, **kwargs)
>>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 545, in save
>>     force_update=force_update, update_fields=update_fields)
>>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line 582, in save_base
>>     update_fields=update_fields, raw=raw, using=using)
>>   File "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185, in send
>>     response = receiver(signal=self, sender=sender, **named)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py", line 470, in geoserver_post_save
>>     set_styles(instance, gs_catalog)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line 777, in set_styles
>>     layer.default_style = save_style(default_style)
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line 792, in save_style
>>     style.sld_title = gs_style.sld_title
>>   File "/usr/lib/python2.7/dist-packages/geoserver/style.py", line 49, in sld_title
>>     title_node = user_style.find("{http://www.opengis.net/sld}Title")
>> Exception: ('Failed to process DOP Hx 2014', AttributeError("'NoneType' object has no attribute 'find'",))
>> I use the raster sld as default renderer. The layer DOP Hx 2014 is an RGB ImageMosaic Datastore.
>> geonode-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-devel mailing list
