[GeoNode-devel] [GeoNode-users] updatelayers not working: NoneType object has no attribute find
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Oct 30 08:14:04 PDT 2015
There should be a fix for SLDs on latest gsconfig versions.
Try to update the dependencies with
pip install -e .
from the GeoNode updated folder.
I'll check the issue though.
Regards,
Alessio.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Oct 29, 2015 at 4:00 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> Lets keep this on the list. Ill update the ticket and see if the
> GeoSolutions guys have any ideas since they have been working on both
> gsconfig and the imagemosaic plugin.
> Jeff
> On Thu, Oct 29, 2015 at 5:00 AM, Florian Hoedt <florian.hoedt at hs-owl.de>
> wrote:
> > Hello Jeffrey,
> > I tried to reopen the ticket but it seems like I am not allowed to do it
> (or I just do not know exactly what to click).
> > Nevertheless here is the stacktrace:
> > https://gist.github.com/gannebamm/1e1cd8442f90769d4c31
> > The Layer is an imagemosaic datastore with the geoserver raster style as
> default style.
> > mit freundlichen Grüßen
> > Florian Hoedt
> > B.Sc. Florian Hoedt
> > Hochschule Ostwestfalen-Lippe / Campus Höxter
> > FB 9 Landschaftsarchitektur und Umweltplanung
> > An der Wilhelmshöhe 44
> > 37671 Höxter
> > Tel.: 05271-687-7478
> > E-Mail: florian.hoedt at hs-owl.de
> > www.hs-owl.de/fb9
> > -----Ursprüngliche Nachricht-----
> > Von: Jeffrey Johnson [mailto:ortelius at gmail.com]
> > Gesendet: Montag, 26. Oktober 2015 17:34
> > An: Florian Hoedt
> > Cc: geonode-users at lists.osgeo.org; geonode-devel at lists.osgeo.org
> > Betreff: Re: [GeoNode-users] updatelayers not working: NoneType object
> > Florian,
> > Can you add your stack trace to the ticket and re-open?
> > Jeff
> > On Mon, Oct 26, 2015 at 2:44 AM, Florian Hoedt <florian.hoedt at hs-owl.de>
> wrote:
> >> Hello List,
> >> Seems like this error still is present:
> >> https://github.com/GeoNode/geonode/issues/869
> >> I have created and deleted a lot of datastores in GeoServer (still
> learning) and after beeing happy with my aerials tried to:
> >> sudo geonode updatelayers --skip-geonode-registered
> >> which gave me:
> >> Traceback (most recent call last):
> >>   File "/usr/bin/django-admin", line 5, in <module>
> >>     management.execute_from_command_line()
> >>   File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 399, in execute_from_command_line
> >>     utility.execute()
> >>   File
> line 392, in execute
> >>     self.fetch_command(subcommand).run_from_argv(self.argv)
> >>   File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
> line 242, in run_from_argv
> >>     self.execute(*args, **options.__dict__)
> >>   File
> line 285, in execute
> >>     output = self.handle(*args, **options)
> >>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py",
> line 108, in handle
> >>     remove_deleted=remove_deleted)
> >>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
> 458, in gs_slurp
> >>     "bbox_y1": Decimal(resource.latlon_bbox[3])
> >>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line
> 154, in get_or_create
> >>     return self.get_queryset().get_or_create(**kwargs)
> >>   File
> "/usr/local/lib/python2.7/dist-packages/modeltranslation/manager.py", line
> 341, in get_or_create
> >>     return super(MultilingualQuerySet, self).get_or_create(**kwargs)
> >>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line
> 383, in get_or_create
> >>     obj.save(force_insert=True, using=self.db)
> >>   File
> "/usr/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py", line
> 90, in save
> >>     return super(PolymorphicModel, self).save(*args, **kwargs)
> >>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py", line
> 545, in save
> >>     force_update=force_update, update_fields=update_fields)
> >>   File
> 582, in save_base
> >>     update_fields=update_fields, raw=raw, using=using)
> >>   File
> "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
> line 185, in send
> >>     response = receiver(signal=self, sender=sender, **named)
> >>   File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py", line
> 470, in geoserver_post_save
> >>     set_styles(instance, gs_catalog)
> >>   File
> 777, in set_styles
> >>     layer.default_style = save_style(default_style)
> >>   File
> 792, in save_style
> >>     style.sld_title = gs_style.sld_title
> >>   File "/usr/lib/python2.7/dist-packages/geoserver/style.py", line 49,
> in sld_title
> >>     title_node = user_style.find("{http://www.opengis.net/sld}Title")
> >> Exception: ('Failed to process DOP Hx 2014', AttributeError("'NoneType'
> object has no attribute 'find'",))
> >> I use the raster sld as default renderer. The layer DOP Hx 2014 is an
> RGB ImageMosaic Datastore.
> >> _______________________________________________
> >> geonode-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151030/bb16aa5e/attachment.html>
More information about the geonode-devel mailing list
