[GeoNode-devel] Geonode Development to Production
Simone Dalmasso simone.dalmasso at gmail.com
Mon Sep 21 03:01:48 PDT 2015
Hi, your problem seems to be in this line:
*WSGIDaemonProcess geonode
python-path=/home/borly/geonode:/home/borly/.venvs/geonode/lib/python2.7/site-packages
user=www-data threads=15 processes=2*
the apache wsgi module cannot find Django and can't import django.core.
Make sure it is isntalled in your
*/home/borly/.venvs/geonode/lib/python2.7/site-packages
*and try to use only that path as python-path
*python-path=/home/borly/.venvs/geonode/lib/python2.7/site-packages*
Hope this helps
2015-09-21 11:52 GMT+02:00 Noel Jerome Borlongan <
njbborlongan.phillidar2.upd at gmail.com>:
> Hi Geonode devs!
> I installed Geonode for Development in my machine, but now we want Geonode
> to be available to public, so what we did was migrate the virtual machine
> containing the Geonode installation to a Proxmox VE. I followed the steps
> discussed here:
> http://geonode.readthedocs.org/en/latest/tutorials/admin/install/custom_install.html.
> Unfortunately, I cannot get pass setting localhost to Geonode webpage using
> Apache2. Here is my geonode.conf:
> *<VirtualHost *:80>*
> *    ServerName localhost*
> *    ServerAdmin webmaster at localhost*
> *    DocumentRoot /home/borly/geonode/geonode*
> *    ErrorLog /var/log/apache2/error.log*
> *    LogLevel warn*
> *    CustomLog /var/log/apache2/access.log combined*
> *    WSGIProcessGroup geonode*
> *    WSGIPassAuthorization On*
> *    WSGIScriptAlias / /home/borly/geonode/geonode/wsgi.py*
> *    <Directory "/home/borly/geonode/geonode/">*
> *        Require all granted*
> *        Options Indexes FollowSymLinks     *
> *        IndexOptions FancyIndexing*
> *    </Directory>*
> *    Alias /static/ /home/borly/geonode/geonode/static/*
> *    Alias /uploaded/ /home/borly/geonode/geonode/uploaded/*
> *    <Proxy *>*
> *    </Proxy>*
> *    ProxyPreserveHost On*
> *    ProxyPass /geoserver http://localhost:8080/geoserver
> <http://localhost:8080/geoserver>*
> *    ProxyPassReverse /geoserver http://localhost:8080/geoserver
> *</VirtualHost>*
> When typing localhost in a web browser, an Internal Server Error occurs
> which says:
> *The server encountered an internal error or misconfiguration and was
> unable to complete your request.*
> *Please contact the server administrator at webmaster at localhost to inform
> them of the time this error occurred, and the actions you performed just
> before this error.*
> *More information about this error may be available in the server error
> log.*
> I checked the Apache2 error log, and it says an *ImportError: No module
> named django.core.wsgi*. I also tried editing wsgi.py (as suggested here:
> http://stackoverflow.com/questions/14927345/importerror-no-module-named-django-core-wsgi-apache-virtualenv-aws-wsgi)
> by adding/appending the geonode path and virtualenv path to sys.path, but
> still the same error occurs.
> Thanks for the help!
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150921/610d4807/attachment.html>
More information about the geonode-devel mailing list
