[GeoNode-devel] Geonode Development to Production
    Noel Jerome Borlongan
    njbborlongan.phillidar2.upd at gmail.com
    Mon Sep 21 04:55:37 PDT 2015
Hi Simone,
It's okay. The machine is dedicated for GeoNode only, so I think there
won't be any other conflict. I have another question, I can now access the
GeoNode webpage, but I cannot view the layers I uploaded when using other
computers. When checking the addresses of the requests, they are pointed to
localhost. What should I change so that they would point to the IP address
of the machine where geoserver is located? Thanks.
On Mon, Sep 21, 2015 at 7:22 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Ok glad it worked, just beware that with sudo you installed GeoNode
> systemwide and you are not using the virtualenv anymore. This is ok but if
> you plan to install other python softwares on the machine be sure to not
> overwrite the libraries with incompatible versions.
> 2015-09-21 12:29 GMT+02:00 Noel Jerome Borlongan <
> njbborlongan.phillidar2.upd at gmail.com>:
>> Hi Simone,
>> Alright thanks for the idea. Since it cannot find Django, I tried
>> reinstalling Django by using "sudo pip install -e .". And voila, it worked!
>> Thanks again.
>> On Mon, Sep 21, 2015 at 6:01 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi, your problem seems to be in this line:
>>> *WSGIDaemonProcess geonode
>>> python-path=/home/borly/geonode:/home/borly/.venvs/geonode/lib/python2.7/site-packages
>>> user=www-data threads=15 processes=2*
>>> the apache wsgi module cannot find Django and can't import django.core.
>>> Make sure it is isntalled in your */home/borly/.venvs/geonode/lib/python2.7/site-packages
>>> *and try to use only that path as python-path
>>> *python-path=/home/borly/.venvs/geonode/lib/python2.7/site-packages*
>>> Hope this helps
>>> 2015-09-21 11:52 GMT+02:00 Noel Jerome Borlongan <
>>>> Hi Geonode devs!
>>>> I installed Geonode for Development in my machine, but now we want
>>>> Geonode to be available to public, so what we did was migrate the virtual
>>>> machine containing the Geonode installation to a Proxmox VE. I followed the
>>>> steps discussed here:
>>>> http://geonode.readthedocs.org/en/latest/tutorials/admin/install/custom_install.html.
>>>> Unfortunately, I cannot get pass setting localhost to Geonode webpage using
>>>> Apache2. Here is my geonode.conf:
>>>> *<VirtualHost *:80>*
>>>> *    ServerName localhost*
>>>> *    ServerAdmin webmaster at localhost*
>>>> *    DocumentRoot /home/borly/geonode/geonode*
>>>> *    ErrorLog /var/log/apache2/error.log*
>>>> *    LogLevel warn*
>>>> *    CustomLog /var/log/apache2/access.log combined*
>>>> *    WSGIProcessGroup geonode*
>>>> *    WSGIPassAuthorization On*
>>>> *    WSGIScriptAlias / /home/borly/geonode/geonode/wsgi.py*
>>>> *    <Directory "/home/borly/geonode/geonode/">*
>>>> *        Require all granted*
>>>> *        Options Indexes FollowSymLinks     *
>>>> *        IndexOptions FancyIndexing*
>>>> *    </Directory>*
>>>> *    Alias /static/ /home/borly/geonode/geonode/static/*
>>>> *    Alias /uploaded/ /home/borly/geonode/geonode/uploaded/*
>>>> *    <Proxy *>*
>>>> *    </Proxy>*
>>>> *    ProxyPreserveHost On*
>>>> *    ProxyPass /geoserver http://localhost:8080/geoserver
>>>> <http://localhost:8080/geoserver>*
>>>> *    ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>>> *</VirtualHost>*
>>>> When typing localhost in a web browser, an Internal Server Error occurs
>>>> which says:
>>>> *The server encountered an internal error or misconfiguration and was
>>>> unable to complete your request.*
>>>> *Please contact the server administrator at webmaster at localhost to
>>>> inform them of the time this error occurred, and the actions you performed
>>>> just before this error.*
>>>> *More information about this error may be available in the server error
>>>> log.*
>>>> I checked the Apache2 error log, and it says an *ImportError: No
>>>> module named django.core.wsgi*. I also tried editing wsgi.py (as
>>>> suggested here:
>>>> http://stackoverflow.com/questions/14927345/importerror-no-module-named-django-core-wsgi-apache-virtualenv-aws-wsgi)
>>>> by adding/appending the geonode path and virtualenv path to sys.path, but
>>>> still the same error occurs.
>>>> Thanks for the help!
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150921/69afc676/attachment-0001.html>
More information about the geonode-devel
