[GeoNode-devel] Time to do a Beta and a Release
Tyler Garner garnertb at prominentedge.com
Fri Sep 25 07:39:58 PDT 2015
We should figure this out too before releasing:
https://github.com/boundlessgeo/gsconfig/issues/91.
I think we should switch to semver for both of the packages.
On Fri, Sep 25, 2015 at 10:37 AM, Jeffrey Johnson <ortelius at gmail.com>
wrote:
> Ariel, can you add Daniel, Alessio and Tyler as owners/maintainers on pypi?
> On Fri, Sep 25, 2015 at 7:18 AM, Daniel Berry <dberry at boundlessgeo.com>
> wrote:
>> Yep, Ariel will need to do that. It might be wise to add a few other
>> people as owners or maintainers to both gsconfig and gsimporter.
>> On Fri, Sep 25, 2015 at 9:00 AM, Jeffrey Johnson <ortelius at gmail.com>
>> wrote:
>>> I believe so. Daniel, if you can make the releases to Pypi, please go
>>> for it. Otherwise we may need help from Ariel.
>>> On Fri, Sep 25, 2015 at 6:59 AM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Yes IMHO
>>>> -A.
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/NWWaa2 for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via Poggio alle Viti 1187
>>>> 55054  Massarosa (LU)
>>>> Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39  331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>> principi dettati dal D.Lgs. 196/2003.
>>>> The information in this message and/or attachments, is intended solely
>>>> for the attention and use of the named addressee(s) and may be confidential
>>>> or proprietary in nature or covered by the provisions of privacy act
>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>> strictly forbidden except previous formal approval of the named
>>>> addressee(s). If you are not the intended recipient, please contact
>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>> information in this message that has been received in error. The sender
>>>> does not give any warranty or accept liability as the content, accuracy or
>>>> completeness of sent messages and accepts no responsibility  for changes
>>>> made after they were sent or for other risks which arise as a result of
>>>> e-mail transmission, viruses, etc.
>>>> On Fri, Sep 25, 2015 at 3:57 PM, Daniel Berry <dberry at boundlessgeo.com>
>>>> wrote:
>>>>> In regards to the gsimporter and gsconfig are we at a point where we
>>>>> can update pypi.
>>>>> I loaded both on testpypi
>>>>> gsimporter - https://testpypi.python.org/pypi/gsimporter/0.2
>>>>> gsconfig - https://testpypi.python.org/pypi/gsconfig/0.6.14
>>>>> Dan
>>>>> On Fri, Sep 25, 2015 at 4:04 AM, Paolo Corti <pcorti at gmail.com> wrote:
>>>>>> Hi Alessio
>>>>>> > On Fri, Sep 25, 2015 at 10:39 AM, Paolo Corti <pcorti at gmail.com>
>>>>>> wrote:
>>>>>> >> I agree to start releasing a new beta (beta 27) and maybe start
>>>>>> >> thinking about releasing a RC1 (time is short to the sprint).
>>>>>> >> By the way: I see several issues still open regarding GeoServer
>>>>>> >> integration [1], maybe it would be great to do a triage to check
>>>>>> what
>>>>>> >> it was fixed and what it was not.
>>>>>> >> Personally I see #2177 as a blocker to move our production to GS
>>>>>> 2.7.
>>>>>> > I did not have the chance to look deeply in to this yet, but at a
>>>>>> first
>>>>>> > glance I'm not fully sure this depends on GS. It seems to be more
>>>>>> an issue
>>>>>> > on GeoNode side. Do you have any more details? In any case I'll try
>>>>>> to find
>>>>>> > some time to inspect this issue as soon as possible. (Also, make a
>>>>>> try using
>>>>>> > the very latest versions of gsconfig and gsimporter, the
>>>>>> communication
>>>>>> > between the client and GeoServer has several fixes and improvements
>>>>>> which
>>>>>> > maybe already fixed this issue too)
>>>>>> we can look into this at the sprint, and yes you are correct, it is
>>>>>> just Django, sorry for the confusion.
>>>>>> >> Is the SQL security backend correctly working with GS 2.7 [2]?
>>>>>> > Never tested. Can you please send me few lines and details in order
>>>>>> to test
>>>>>> > and troubleshoot this?
>>>>>> http://docs.geonode.org/en/dev/deploy/production.html#installing-the-stored-procedure
>>>>>> hope it helps
>>>>>> cheers
>>>>>> p
>>>>>> Paolo Corti
>>>>>> Geospatial software developer
>>>>>> web: http://www.paolocorti.net
>>>>>> twitter: @capooti
>>>>>> skype: capooti
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>> *Daniel Berry*
>>>>> Professional Services Engineer | Boundless
>>>>> 512-468-3946 (cell)
>>>>> @boundlessgeo
>> *Daniel Berry*
>> 512-468-3946 (cell)
>> @boundlessgeo
*Tyler Garner*
Co-Founder | Prominent Edge
Office: 703-743-5434
Mobile: 434-841-3803
prominentedge.com
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150925/512190ec/attachment.html>
More information about the geonode-devel mailing list
