[GeoNode-devel] Time to do a Beta and a Release
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Sep 25 10:04:36 PDT 2015
+1 on the artifacts releases
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, Sep 25, 2015 at 6:11 PM, Ariel Nunez <ingenieroariel at gmail.com>
wrote:
> I can take care of releasing the artifacts (or make sure whoever wants to
> do it has the right permissions over there)
> -a
> On Fri, Sep 25, 2015 at 9:43 AM, Daniel Berry <dberry at boundlessgeo.com>
> wrote:
>> maybe gsconfig 7.0.0 and gsimporter 1.0.0
>> On Fri, Sep 25, 2015 at 9:39 AM, Tyler Garner <garnertb at prominentedge.com
>> > wrote:
>>> We should figure this out too before releasing:
>>> https://github.com/boundlessgeo/gsconfig/issues/91.
>>> I think we should switch to semver for both of the packages.
>>> On Fri, Sep 25, 2015 at 10:37 AM, Jeffrey Johnson <ortelius at gmail.com>
>>> wrote:
>>>> Ariel, can you add Daniel, Alessio and Tyler as owners/maintainers on
>>>> pypi?
>>>> On Fri, Sep 25, 2015 at 7:18 AM, Daniel Berry <dberry at boundlessgeo.com>
>>>> wrote:
>>>>> Yep, Ariel will need to do that. It might be wise to add a few other
>>>>> people as owners or maintainers to both gsconfig and gsimporter.
>>>>> On Fri, Sep 25, 2015 at 9:00 AM, Jeffrey Johnson <ortelius at gmail.com>
>>>>> wrote:
>>>>>> I believe so. Daniel, if you can make the releases to Pypi, please go
>>>>>> for it. Otherwise we may need help from Ariel.
>>>>>> On Fri, Sep 25, 2015 at 6:59 AM, Alessio Fabiani <
>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>> Yes IMHO
>>>>>>> -A.
>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>> The information in this message and/or attachments, is intended
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>> e-mail transmission, viruses, etc.
>>>>>>> On Fri, Sep 25, 2015 at 3:57 PM, Daniel Berry <
>>>>>>> dberry at boundlessgeo.com> wrote:
>>>>>>>> In regards to the gsimporter and gsconfig are we at a point where
>>>>>>>> we can update pypi.
>>>>>>>> I loaded both on testpypi
>>>>>>>> gsimporter - https://testpypi.python.org/pypi/gsimporter/0.2
>>>>>>>> gsconfig - https://testpypi.python.org/pypi/gsconfig/0.6.14
>>>>>>>> Dan
>>>>>>>> On Fri, Sep 25, 2015 at 4:04 AM, Paolo Corti <pcorti at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Hi Alessio
>>>>>>>>> > On Fri, Sep 25, 2015 at 10:39 AM, Paolo Corti <pcorti at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>> >> I agree to start releasing a new beta (beta 27) and maybe start
>>>>>>>>> >> thinking about releasing a RC1 (time is short to the sprint).
>>>>>>>>> >> By the way: I see several issues still open regarding GeoServer
>>>>>>>>> >> integration [1], maybe it would be great to do a triage to
>>>>>>>>> check what
>>>>>>>>> >> it was fixed and what it was not.
>>>>>>>>> >> Personally I see #2177 as a blocker to move our production to
>>>>>>>>> GS 2.7.
>>>>>>>>> > I did not have the chance to look deeply in to this yet, but at
>>>>>>>>> a first
>>>>>>>>> > glance I'm not fully sure this depends on GS. It seems to be
>>>>>>>>> more an issue
>>>>>>>>> > on GeoNode side. Do you have any more details? In any case I'll
>>>>>>>>> try to find
>>>>>>>>> > some time to inspect this issue as soon as possible. (Also, make
>>>>>>>>> a try using
>>>>>>>>> > the very latest versions of gsconfig and gsimporter, the
>>>>>>>>> communication
>>>>>>>>> > between the client and GeoServer has several fixes and
>>>>>>>>> improvements which
>>>>>>>>> > maybe already fixed this issue too)
>>>>>>>>> we can look into this at the sprint, and yes you are correct, it is
>>>>>>>>> just Django, sorry for the confusion.
>>>>>>>>> >> Is the SQL security backend correctly working with GS 2.7 [2]?
>>>>>>>>> > Never tested. Can you please send me few lines and details in
>>>>>>>>> order to test
>>>>>>>>> > and troubleshoot this?
>>>>>>>>> http://docs.geonode.org/en/dev/deploy/production.html#installing-the-stored-procedure
>>>>>>>>> hope it helps
>>>>>>>>> cheers
>>>>>>>>> p
>>>>>>>>> Paolo Corti
>>>>>>>>> Geospatial software developer
>>>>>>>>> web: http://www.paolocorti.net
>>>>>>>>> twitter: @capooti
>>>>>>>>> skype: capooti
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-devel mailing list
>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>>>>> *Daniel Berry*
>>>>>>>> Professional Services Engineer | Boundless
>>>>>>>> 512-468-3946 (cell)
>>>>>>>> @boundlessgeo
>>>>> *Daniel Berry*
>>>>> 512-468-3946 (cell)
>>>>> @boundlessgeo
>>> *Tyler Garner*
>>> Co-Founder | Prominent Edge
>>> Office: 703-743-5434
>>> Mobile: 434-841-3803
>>> prominentedge.com
>> *Daniel Berry*
>> 512-468-3946 (cell)
>> @boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150925/66b370e6/attachment-0001.html>
More information about the geonode-devel mailing list
