[GeoNode-devel] Costumize metadata geonode editor
Ariel Nunez ingenieroariel at gmail.com
Tue Sep 29 09:02:55 PDT 2015
You just need to modify models.py and the editor will be updated
automagically. Here is an example:
https://github.com/GFDRR/geonode/commit/29b1a22f186b811b2bdf5014b18ea6bde120c95b
The key is doing this *before* you load any data on the geonode, because
the tables need to be created with different fields.
-a
On Tue, Sep 29, 2015 at 10:48 AM, Eduardo Pascoal <pascoal.egeo at gmail.com>
wrote:
> Ariel Nunez,
> thanks for your prompt answer but probably i didn't make myself clear..
> That is an interesting point to do.  Fork geonode and create a INSPIRE
> branch with the new metadata editor which for sure would be great for
> geonode but my problem is beyond that.
> My question it has to do with the begining of all this. How to costumize
> geonode editor? How dificult is to do that? Geonode predict this kind of
> costumization? What modifications should i consider?
> 2015-09-29 16:14 GMT+01:00 Ariel Nunez <ingenieroariel at gmail.com>:
>> When modifying the metadata schema, my approach has been to just fork
>> GeoNode and keep the changes restricted to ONLY that change.
>> The workflow would be:
>> 1. Make sure you have a master branch in your repo that is an exact copy
>> of GeoNode master.
>> 2. Create a branch with your project name or called 'inspire' for
>> example. Commit the metadata changes there.
>> 3. If you installed via packages, replace the existing geonode with your
>> version (careful with local_settings.py), clone it via git and then do pip
>> install -e on the folder
>> 4. When 2.4 is final, update your version of master with the latest from
>> GeoNode master (exact copy).
>> 5. Merge your master into your inspire branch.
>> 6. Pull the changes from your server into the folder where you did the
>> git clone and reload apache.
>> It sounds a bit convoluted but has worked for me, metadata changes are
>> not easy to do as external apps, contrib or extensions ...
>> -a
>> On Tue, Sep 29, 2015 at 10:02 AM, Eduardo Pascoal <pascoal.egeo at gmail.com
>> > wrote:
>>> Dear all,
>>> *Scenario:*
>>> i have my own metadata profile based on ISO19139 and INSPIRE
>>> implementation rules. I would like to understand how can i modify the
>>> geonode metadata editor with extra fields according to my own metadata
>>> profile.
>>> *Question*
>>> What is the best approach to do a metadata editor?  Should i edit base
>>> app on contrib folder and update model.py? or create my own app that should
>>> override base? What dependencies must i consider to do this?
>>> Do you know any documentation about this subject that you suggest?
>>> Any help would be great
>>> Best regards,
>>> Eduardo Pascoal
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
> Eduardo Pascoal
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150929/aaba14ca/attachment-0001.html>
More information about the geonode-devel mailing list
