[GeoNode-devel] Update the BBOX of an existing layer
Dimitris Karakostis karakostis.dimitris at gmail.com
Thu Aug 4 05:17:42 PDT 2016
Some extra links on geoserver's RESTapi on the recalculate parameter:
http://docs.geoserver.org/stable/en/user/rest/api/featuretypes.html#recalculate
and the layer_metadata view:
https://github.com/wfp-ose/geonode/blob/master/geonode/layers/views.py#L297
Thanks
Dimitris
On Thu, Aug 4, 2016 at 2:10 PM, Dimitris Karakostis <
karakostis.dimitris at gmail.com> wrote:
> I am working on the development of a functionality where the user can
> add/edit the location of existing features (points etc.)
> When I add the new point then I use the <<recalculate>> parameter (from
> geoserver) in order to update the BBOX in the geoserver.
> But I can not find out how to update the BBOX stored in the CSW.
> I have found out, that if I manually update the layer's metadata, then the
> BBOX in the model is replaced with the correct one.
> But looking at the layer_metadata view, I am not sure, which is the
> function that actually does this.
> Can someone point me to the right direction?
> Thanks.
> Dimitris
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160804/5f67afd2/attachment.html>
More information about the geonode-devel mailing list
