[GeoNode-devel] Thumbnail update fails
Simone Dalmasso simone.dalmasso at gmail.com
Mon Aug 29 05:06:06 PDT 2016
And if you open that url in your browser you get a 405 too?
In the layer detail page a 405 on /rest/styles is expected and is the
correct behavior. But not more than one.
2016-08-29 13:52 GMT+02:00 Guillaume Sueur <no-reply at neogeo-online.net>:
> Hi, thanks for your reply,
> Nothing shows up in the log, even in developer logging mode.
> Anyway, what is strange is that I get a 405 error (method not allowed)
> and not a 401 (authentication needed). The requested URL is correct
> though... :
> http://localhost:8080/geoserver/rest/printng/render.
> png?width=240&auth=*************************&height=180
> (auth account and realm are correct too).
> Best regards
> Guillaume
> Le 29/08/2016 à 13:37, Simone Dalmasso a écrit :
> > Hi, try to take a look at the geoserver logs to see if there is a
> > problem with authenticating with geonode or a missing permission (but I
> > don't think). It may just be a small misconfiguration in geoserver.
> > Hope this helps
> png?width=240&auth=geonode.aua-toulouse
> .org%2Cguillaume%2Ccatch22&height=180
> > 2016-08-29 12:23 GMT+02:00 Guillaume Sueur <no-reply at neogeo-online.net
> > <mailto:no-reply at neogeo-online.net>>:
> >     Hi list,
> >     I am experiencing a weird problem with geonode and geoserver rest
> API.
> >     Here is the story. I have a bunch of layers in Geoserver, and I can
> >     updatelayers from Geonode without any problem, having the thumbnails
> >     correctly created in uploaded/thumbs directory, and correctly set to
> >     www-data ownership afterwards to avoid any problem when updating from
> >     the web interface.
> >     Then, if I use the "Define Thumbnail" button from the Layer Edit
> Window,
> >     an empty image is created over the previously created thumbnail. I
> dig a
> >     bit into the code trying to locate the issue. It seems it comes from
> >     geoserver api which replies to the request emitted in
> >     geoserver/helpers.py on line 1687 with :
> >     Thumbnail created : {'date': 'Mon, 29 Aug 2016 10:19:56 GMT',
> 'status':
> >     '405', 'content-length': '0'
> >     , 'allow': 'GET', 'server': 'Noelios-Restlet-Engine/1.0..8'}
> >     which means that the Method Not allowed error wasn't caught back
> >     correctly by geonode who continued the process and wrote the empty
> >     content to a new file.
> >     I just don't understand why I received this 405 HTTP error in this
> >     situation, that I have seen working well on other Geonode Instances.
> >     I've made the installation following the custom installation guide
> last
> >     week, so I guess with some fresh github code.
> >     Any clue ?
> >     Best regards
> >     Guillaume
> >     _______________________________________________
> >     geonode-devel mailing list
> >     geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
> >     http://lists.osgeo.org/mailman/listinfo/geonode-devel
> >     <http://lists.osgeo.org/mailman/listinfo/geonode-devel>
> > Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160829/7c81ae67/attachment.html>
More information about the geonode-devel mailing list
