[GeoNode-devel] Thumbnail update fails
Guillaume Sueur no-reply at neogeo-online.net
Mon Aug 29 06:44:18 PDT 2016
I'm gonna try with
http://build.geonode.org/geoserver/latest/geoserver.war and see what
happens.
Thanks for your kind advices
Guillaume
Le 29/08/2016 à 15:40, Francesco Bartoli a écrit :
> Maybe you can try with the official stable version 2.9.1 of geoserver
> just making the operations manually with curl and see if the problem is
> still happening careless of geonode.
> Regards,
> Francesco
> Il giorno 29/ago/2016, alle ore 15:32, Simone Dalmasso
> <simone.dalmasso at gmail.com <mailto:simone.dalmasso at gmail.com>> ha scritto:
>> Indeed is strange. Try to delete geoserver and the war file and run
>> paver setup again. Let's see how it goes with a new one. (save your
>> data dir if needed)
>> 2016-08-29 15:28 GMT+02:00 Guillaume Sueur <no-reply at neogeo-online.net
>> <mailto:no-reply at neogeo-online.net>>:
>>     Hi again,
>>     It's really weird. It seems that the printing module is correctly
>>     activated (geoserver/pdf/info.json sends some content,
>>     corresponding to
>>     the correct config.yaml file).
>>     But it's like the bindings with the REST API is not done. On another
>>     instance, if I request
>>     localhost:8080/geoserver/rest/printng/render.png
>>     I have an empty PNG in return. On this one, I keep having this
>>     damn 405
>>     error, just because it is not recognized by the REST API I guess.
>>     Any clue here ? Maybe I should ask the Geoserver mailing list. It's
>>     always hard to guess with these cross-software / configuration
>>     problems.
>>     Best regards
>>     Guillaume
>>     Le 29/08/2016 à 14:06, Simone Dalmasso a écrit :
>>     > And if you open that url in your browser you get a 405 too?
>>     > In the layer detail page a 405 on /rest/styles is expected and is the
>>     > correct behavior. But not more than one.
>>     > 2016-08-29 13:52 GMT+02:00 Guillaume Sueur <no-reply at neogeo-online.net <mailto:no-reply at neogeo-online.net>
>>     <mailto:no-reply at neogeo-online.net>>>:
>>     >     Hi, thanks for your reply,
>>     >     Nothing shows up in the log, even in developer logging mode.
>>     >     Anyway, what is strange is that I get a 405 error (method not allowed)
>>     >     and not a 401 (authentication needed). The requested URL is correct
>>     >     though... :
>>     >     http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=*************************&height=180
>>     <http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=*************************&height=180>
>>     <http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=*************************&height=180>>
>>     >     (auth account and realm are correct too).
>>     >     Best regards
>>     >     Guillaume
>>     >     Le 29/08/2016 à 13:37, Simone Dalmasso a écrit :
>>     >     > Hi, try to take a look at the geoserver logs to see if there is a
>>     >     > problem with authenticating with geonode or a missing permission
>>     >     (but I
>>     >     > don't think). It may just be a small misconfiguration in geoserver.
>>     >     > Hope this helps
>>     >     http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=geonode.aua-toulouse
>>     <http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=geonode.aua-toulouse>
>>     >     .org%2Cguillaume%2Ccatch22&height=180
>>     >     .org%2Cguillaume%2Ccatch22&height=180>
>>     >     > 2016-08-29 12:23 GMT+02:00 Guillaume Sueur
>>     <mailto:no-reply at neogeo-online.net>>>>:
>>     >     >     Hi list,
>>     >     >     I am experiencing a weird problem with geonode and
>>     geoserver
>>     >     rest API.
>>     >     >     Here is the story. I have a bunch of layers in
>>     Geoserver, and
>>     >     I can
>>     >     >     updatelayers from Geonode without any problem, having the
>>     >     thumbnails
>>     >     >     correctly created in uploaded/thumbs directory, and
>>     correctly
>>     >     set to
>>     >     >     www-data ownership afterwards to avoid any problem when
>>     >     updating from
>>     >     >     the web interface.
>>     >     >     Then, if I use the "Define Thumbnail" button from the
>>     Layer
>>     >     Edit Window,
>>     >     >     an empty image is created over the previously created
>>     >     thumbnail. I dig a
>>     >     >     bit into the code trying to locate the issue. It seems it
>>     >     comes from
>>     >     >     geoserver api which replies to the request emitted in
>>     >     >     geoserver/helpers.py on line 1687 with :
>>     >     >     Thumbnail created : {'date': 'Mon, 29 Aug 2016
>>     10:19:56 GMT',
>>     >     'status':
>>     >     >     '405', 'content-length': '0'
>>     >     >     , 'allow': 'GET', 'server':
>>     'Noelios-Restlet-Engine/1.0..8'}
>>     >     >     which means that the Method Not allowed error wasn't
>>     caught back
>>     >     >     correctly by geonode who continued the process and
>>     wrote the empty
>>     >     >     content to a new file.
>>     >     >     I just don't understand why I received this 405 HTTP
>>     error in this
>>     >     >     situation, that I have seen working well on other Geonode
>>     >     Instances.
>>     >     >     I've made the installation following the custom
>>     installation
>>     >     guide last
>>     >     >     week, so I guess with some fresh github code.
>>     >     >     Any clue ?
>>     >     >     Best regards
>>     >     >     Guillaume
>>     >     >     _______________________________________________
>>     >     >     geonode-devel mailing list
>>     >     >     geonode-devel at lists.osgeo.org
>>     <mailto:geonode-devel at lists.osgeo.org>
>>     <mailto:geonode-devel at lists.osgeo.org>>
>>     <mailto:geonode-devel at lists.osgeo.org>>>
>>     >     >     http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>     <http://lists.osgeo.org/mailman/listinfo/geonode-devel>
>>     <http://lists.osgeo.org/mailman/listinfo/geonode-devel>>
>>     <http://lists.osgeo.org/mailman/listinfo/geonode-devel>>>
>>     >     > Simone
>>     > Simone
>> Simone
>> geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
More information about the geonode-devel mailing list
