[GeoNode-devel] Support for additional types in upload
Simone Dalmasso simone.dalmasso at gmail.com
Mon Dec 12 07:01:19 PST 2016
Hi Jivan,
this interesting indeed, though the community is working on the
https://github.com/GeoNode/django-osgeo-importer which will be used in
GeoNode soon as default way to import data. Do you think that your work can
fit in that one?
2016-12-05 19:59 GMT+01:00 Jivan Amara <development at jivanamara.net>:
> > Message: 1
> > Date: Fri, 25 Nov 2016 15:52:17 +0000
> > From: Eric Groning <eg at novel-t.ch>
> > To: "geonode-devel at lists.osgeo.org" <geonode-devel at lists.osgeo.org>
> > Subject: [GeoNode-devel] Support for additional types in upload
> > Message-ID:
> >       <VI1PR04MB1181179E9070D8AD3FE1F96FFA890 at VI1PR04MB1181.
> eurprd04.prod.outlook.com>
> > Content-Type: text/plain; charset="iso-8859-1"
> > Hello,
> > I'm currently adding FGDB support for the upload for a project based on
> a customized geonode.  Since it might be a feature the community is
> interested in, I figured it's worth it to mention in this list.  I also
> have a few questions.
> > First, here is a rough outline of what I'm changing:
> > -Use gdal 2.1.2 (the latest) compiled with FileGDB support (via
> GDAL_LIBRARY_PATH in Django settings)
> > -Change layer forms / upload / geoserver signals to accept a zipped fgdb
> > -Change geoserver_pre_save to use call ogr2ogr directly to convert the
> FGDB to the geoserver data Postgis database (as geoserver won't convert an
> uploaded FGDB as it does with shapefiles)
> > Second, with regards to adding this to geonode via pull request:
> > The implementation I'm doing wouldn't really be directly merge-able.  To
> do this properly, there would likely need to be some refactoring done to
> make the upload generic and extensible (like to easily add more gdal
> supported types with different file structures / extentions such as KML /
> Postgis backups / GML / SqLite / GeoJSON / etc).   The configuration would
> have impacts on how the upload form is validated, the layer upload
> javascript, the model, and how the layer is uploaded to geoserver.  So not
> a light / easy change :)
> > A side issue is that for some formats, you can have multiple layers.  As
> such, it would be nice to have the UI handle multiple layers (ie let the
> user choose which layers to upload)
> > For reference, below are links to some shapefile specific handling in
> the code --
> > https://github.com/GeoNode/geonode/blob/master/geonode/
> layers/utils.py#L94
> layers/forms.py#L81
> geoserver/helpers.py#L1084
> > The questions are:
> > Is supporting more types / making the upload more generic a planned
> feature for a future geonode release?
> > What would be the pros / cons to this approach vs an approach like first
> converting the upload to a shapefile (like in the layer_upload view), then
> use the existing upload flow?
> > Any pain points / gotchas in the above approach?
> > Best regards,
> > Eric
> > Novel-T Sàrl
> > Eric GRÖNING - Solutions Engineer
> > W: www.novel-t.ch<http://www.novel-t.ch/> | @: eg at novel-t.ch<mailto:
> eg at novel-t.ch>
> Hi Eric,
> This project is for making uploads generic:
> https://github.com/geonode/django-osgeo-importer and we're going to be
> working on FGDB support.  The approach you outlined looks good, I'd just
> suggest doing it as part of the importer.
> Cheers,
> Jivan Amara
> Senior Software Developer / System Administrator
> Development at JivanAmara.net
> geonode-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161212/b57fb04b/attachment.html>
More information about the geonode-devel mailing list
