[GeoNode-devel] Problems restoring Geonode Data
Simone Dalmasso simone.dalmasso at gmail.com
Sun Feb 14 23:10:29 PST 2016
in the geoseerver admin, put the correct credentials in the definition of
the store that geoserver is using to connect to postgres. This happens if
the postgres password has been changed during the restore.
2016-02-14 22:50 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
> Just as an update of this issue. I tried to use the geonode database user
> password generated in the server where the backups are generated in the
>  server I use as a test but then the application crashes, I checked in the
> error log of the apache and says "authentication failed".    Rgds  Rodrigo
> On Sun, Feb 14, 2016 at 4:20 PM, Rodrigo Esquivel <
> rodrigo.esquivel at gmail.com> wrote:
>> Thanks Simone, I appreciate your patience and time spent with me. The
>> thumbs are appearing but now I do not have the layer itself in the map( see
>> attached file), touching here and there also noticed that when I try to
>> download the layer I have an authentication error. I suspect that they are
>> both sides of the same problem. What do you recommend to check?
>> Best Regards from Panama,
>> Rodrigo Esquivel
>> On Sun, Feb 14, 2016 at 2:32 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> the thumbnails are saved in /var /www/geonode. if you restore that one
>>> you'll get them back.
>>> hope it helps
>>> 2016-02-14 5:48 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
>>>> Good night  .. thanks for the advice it seems that somehow the first
>>>> dump I generated  was corrupted.  I generated a new one, restored it and I
>>>> didn't have any problem accessing the application.   However even though I
>>>> have access to the layers,  the preview is not appearing( see
>>>> troubleshootingrestore.png)  Looking in older  mails I thought that the
>>>> problem could be in the web.xml or in the local_settings.py, but both
>>>> seemed normal to me so I suspect that besides the subdirectories
>>>> /usr/share/geoserver/data and /var/lib/geoserver  I have to take in account
>>>> another one.
>>>> Thanks for your Time,
>>>> Rodrigo Esquivel
>>>> On Sat, Feb 13, 2016 at 2:45 AM, Simone Dalmasso <
>>>>> Hi,
>>>>> the error tells that either your db is not configured with postgis
>>>>> (but if you have restored then it should be) of you have to add
>>>>> POSTGIS_VERSION=(2,1,0) to your settings.
>>>>> 2016-02-13 4:38 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com
>>>>>> Hello All, I  am making some  backup and restore tests.  I followed
>>>>>> all the information I found in the net:  Backup of the Database and the
>>>>>> files  in the directories /usr/share/geoserver/data  and
>>>>>> /var/lib/geoserver/geonode-data.  After I restore the Data Base backup and
>>>>>> the sub-directories  I have an error 500 when I try to run the application.
>>>>>>   The Apache's log is telling me that there is some file that do not have
>>>>>> permission to be accessed( I am attaching the file)  I am using   Geonode R
>>>>>> 2.09 and Ubuntu 12.04. Does anyone could tell me  if there is any thing
>>>>>> else I need to do?   Thanks in advance for your time.
>>>>>> Rodrigo Esquivel
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> Simone
>>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160215/82b2e311/attachment.html>
More information about the geonode-devel mailing list
