[GeoNode-devel] Problems restoring Geonode Data
Rodrigo Esquivel rodrigo.esquivel at gmail.com
Wed Feb 17 04:49:25 PST 2016
Thanks for your help Simone, I will start from scratch applying what you
wrote me and I will let you know of anything else.
Rgds
Rodrigo Esquivel
On Mon, Feb 15, 2016 at 2:10 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> in the geoseerver admin, put the correct credentials in the definition of
> the store that geoserver is using to connect to postgres. This happens if
> the postgres password has been changed during the restore.
> 2016-02-14 22:50 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
>> Just as an update of this issue. I tried to use the geonode database user
>> password generated in the server where the backups are generated in the
>>  server I use as a test but then the application crashes, I checked in the
>> error log of the apache and says "authentication failed".    Rgds  Rodrigo
>> On Sun, Feb 14, 2016 at 4:20 PM, Rodrigo Esquivel <
>> rodrigo.esquivel at gmail.com> wrote:
>>> Thanks Simone, I appreciate your patience and time spent with me. The
>>> thumbs are appearing but now I do not have the layer itself in the map( see
>>> attached file), touching here and there also noticed that when I try to
>>> download the layer I have an authentication error. I suspect that they are
>>> both sides of the same problem. What do you recommend to check?
>>> Best Regards from Panama,
>>> Rodrigo Esquivel
>>> On Sun, Feb 14, 2016 at 2:32 AM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> the thumbnails are saved in /var /www/geonode. if you restore that one
>>>> you'll get them back.
>>>> hope it helps
>>>> 2016-02-14 5:48 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>
>>>>> Good night  .. thanks for the advice it seems that somehow the first
>>>>> dump I generated  was corrupted.  I generated a new one, restored it and I
>>>>> didn't have any problem accessing the application.   However even though I
>>>>> have access to the layers,  the preview is not appearing( see
>>>>> troubleshootingrestore.png)  Looking in older  mails I thought that the
>>>>> problem could be in the web.xml or in the local_settings.py, but both
>>>>> seemed normal to me so I suspect that besides the subdirectories
>>>>> /usr/share/geoserver/data and /var/lib/geoserver  I have to take in account
>>>>> another one.
>>>>> Thanks for your Time,
>>>>> Rodrigo Esquivel
>>>>> On Sat, Feb 13, 2016 at 2:45 AM, Simone Dalmasso <
>>>>>> Hi,
>>>>>> the error tells that either your db is not configured with postgis
>>>>>> (but if you have restored then it should be) of you have to add
>>>>>> POSTGIS_VERSION=(2,1,0) to your settings.
>>>>>> 2016-02-13 4:38 GMT+01:00 Rodrigo Esquivel <
>>>>>>> Hello All, I  am making some  backup and restore tests.  I followed
>>>>>>> all the information I found in the net:  Backup of the Database and the
>>>>>>> files  in the directories /usr/share/geoserver/data  and
>>>>>>> /var/lib/geoserver/geonode-data.  After I restore the Data Base backup and
>>>>>>> the sub-directories  I have an error 500 when I try to run the application.
>>>>>>>   The Apache's log is telling me that there is some file that do not have
>>>>>>> permission to be accessed( I am attaching the file)  I am using   Geonode R
>>>>>>> 2.09 and Ubuntu 12.04. Does anyone could tell me  if there is any thing
>>>>>>> else I need to do?   Thanks in advance for your time.
>>>>>>> Rodrigo Esquivel
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>> Simone
>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160217/1b6a4495/attachment.html>
More information about the geonode-devel mailing list
