[GeoNode-devel] Problems restoring Geonode Data
Rodrigo Esquivel rodrigo.esquivel at gmail.com
Fri Feb 19 08:28:51 PST 2016
Hello Alessio: I am sending the log  comprised, hope it can help;  what I
made today was to try to open a layer and try to  download a file from it,
so you can check the logs dated on Feb 19th, 2016.  Just to give you a
context I am running Geonode R 2.01 on Ubuntu 12.04.  I am also sending the
data store screenshots in case it can help.  As always,  thanks to you and
Simone for your time.
Rgds
Rodrigo
On Fri, Feb 19, 2016 at 10:13 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Rodrigo,
> if you have admin rights to GeoNode, go to the GeoServer administration
> page, click on " Settings > Global " and select "VERBOSE_LOGGING" profile.
> Save and try to make a query again.
> Go back to the GeoServer administration page, click on " GeoServer logs "
> and try to catch the Exception Stacktrace. You can also download the file,
> compress it and send here in order to take a look.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Fri, Feb 19, 2016 at 4:05 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> There must be something missing the datastore definition. Any error in
>> the geoserver datastore admin panel?
>> 2016-02-19 2:04 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
>>> Hi Simone, thanks for the advice now the system can download csv files
>>> without any problem but still can not display the layer,  Tried to download
>>> a kml file or jpg and I have a "not properly configured datastore" error( I
>>> think that they are related errors).  Any other place that I have to look
>>> at?
>>> Best Regards and thanks for your time,
>>> Rodrigo
>>> On Wed, Feb 17, 2016 at 7:49 AM, Rodrigo Esquivel <
>>> rodrigo.esquivel at gmail.com> wrote:
>>>> Thanks for your help Simone, I will start from scratch applying what
>>>> you wrote me and I will let you know of anything else.
>>>> Rgds
>>>> Rodrigo Esquivel
>>>> On Mon, Feb 15, 2016 at 2:10 AM, Simone Dalmasso <
>>>>> in the geoseerver admin, put the correct credentials in the definition
>>>>> of the store that geoserver is using to connect to postgres. This happens
>>>>> if the postgres password has been changed during the restore.
>>>>> 2016-02-14 22:50 GMT+01:00 Rodrigo Esquivel <
>>>>>> Just as an update of this issue. I tried to use the geonode database
>>>>>> user password generated in the server where the backups are generated in
>>>>>> the  server I use as a test but then the application crashes, I checked in
>>>>>> the error log of the apache and says "authentication failed".    Rgds
>>>>>>  Rodrigo
>>>>>> On Sun, Feb 14, 2016 at 4:20 PM, Rodrigo Esquivel <
>>>>>>> Thanks Simone, I appreciate your patience and time spent with me.
>>>>>>> The thumbs are appearing but now I do not have the layer itself in the map(
>>>>>>> see attached file), touching here and there also noticed that when I try to
>>>>>>> download the layer I have an authentication error. I suspect that they are
>>>>>>> both sides of the same problem. What do you recommend to check?
>>>>>>> Best Regards from Panama,
>>>>>>> Rodrigo Esquivel
>>>>>>> On Sun, Feb 14, 2016 at 2:32 AM, Simone Dalmasso <
>>>>>>>> the thumbnails are saved in /var /www/geonode. if you restore that
>>>>>>>> one you'll get them back.
>>>>>>>> hope it helps
>>>>>>>> 2016-02-14 5:48 GMT+01:00 Rodrigo Esquivel <
>>>>>>>>> Good night  .. thanks for the advice it seems that somehow the
>>>>>>>>> first dump I generated  was corrupted.  I generated a new one, restored it
>>>>>>>>> and I didn't have any problem accessing the application.   However even
>>>>>>>>> though I have access to the layers,  the preview is not appearing( see
>>>>>>>>> troubleshootingrestore.png)  Looking in older  mails I thought that the
>>>>>>>>> problem could be in the web.xml or in the local_settings.py, but both
>>>>>>>>> seemed normal to me so I suspect that besides the subdirectories
>>>>>>>>> /usr/share/geoserver/data and /var/lib/geoserver  I have to take in account
>>>>>>>>> another one.
>>>>>>>>> Thanks for your Time,
>>>>>>>>> Rodrigo Esquivel
>>>>>>>>> On Sat, Feb 13, 2016 at 2:45 AM, Simone Dalmasso <
>>>>>>>>>> Hi,
>>>>>>>>>> the error tells that either your db is not configured with
>>>>>>>>>> postgis (but if you have restored then it should be) of you have to add
>>>>>>>>>> POSTGIS_VERSION=(2,1,0) to your settings.
>>>>>>>>>> 2016-02-13 4:38 GMT+01:00 Rodrigo Esquivel <
>>>>>>>>>>> Hello All, I  am making some  backup and restore tests.  I
>>>>>>>>>>> followed all the information I found in the net:  Backup of the Database
>>>>>>>>>>> and the files  in the directories /usr/share/geoserver/data  and
>>>>>>>>>>> /var/lib/geoserver/geonode-data.  After I restore the Data Base backup and
>>>>>>>>>>> the sub-directories  I have an error 500 when I try to run the application.
>>>>>>>>>>>   The Apache's log is telling me that there is some file that do not have
>>>>>>>>>>> permission to be accessed( I am attaching the file)  I am using   Geonode R
>>>>>>>>>>> 2.09 and Ubuntu 12.04. Does anyone could tell me  if there is any thing
>>>>>>>>>>> else I need to do?   Thanks in advance for your time.
>>>>>>>>>>> Rodrigo Esquivel
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160219/affb01d2/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160219/affb01d2/attachment-0001.zip>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160219/affb01d2/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160219/affb01d2/attachment-0003.png>
More information about the geonode-devel mailing list
