[GeoNode-devel] 2.4.x Branch
Francesco Bartoli xbartolone at gmail.com
Tue Jan 5 03:15:23 PST 2016
Hi all,
anyone who can create the 2.4 branch?
Thanks and happy new year!
Francesco
> On Dec 2 2015, at 4:32 pm, Tom Kralidis <tom.kralidis at gmail.com>
wrote:
> Exactly. +1
Sent from my iPhone
On Dec 2, 2015, at 10:26, Ariel Nunez
<[ingenieroariel at gmail.com](mailto:ingenieroariel at gmail.com)> wrote:
>> Patrick,
>> What I understood is that it means less alpha/beta/rc craze and just
knowing that the 2.5.x releases would be 'development' and should not be used
in production.
>> -a
>> On Wed, Dec 2, 2015 at 10:24 AM, Jeffrey Johnson
<[ortelius at gmail.com](mailto:ortelius at gmail.com)> wrote:
>>> <http://producingoss.com/en/development-cycle.html#release-number-even-
odd-strategy>
On Wed, Dec 2, 2015 at 10:22 PM, Patrick Dufour
<[pjdufour.dev at gmail.com](mailto:pjdufour.dev at gmail.com)> wrote:
> By even/odd, do you mean bug fixes would be,
> 2.4.1, 2.4.3, 2.4.5, 2.4.7, etc.
> And that the stable releases will be:
> 2.6.0, 2.8.0, 2.10.0, 2.12.0, etc.
> Or some other sequence.
> In regards, to the top number, I'd vote to stay on 2.x.x for a while and
> only migrate to 3.x.x when there's a massive change.
> On Dec 2, 2015 9:57 AM, "Paolo Corti"
<[pcorti at gmail.com](mailto:pcorti at gmail.com)> wrote:
>> +1 for even/odd and for 2.4.1 release
>> cheers
>> p
>> On Wed, Dec 2, 2015 at 9:29 AM, Alessio Fabiani
>> <[alessio.fabiani at geo-solutions.it](mailto:alessio.fabiani at geo-
solutions.it)> wrote:
>> > It should not, the GeoServer version is the same train. There
can be an
>> > issue if the users run a "paver setup" command maybe, which (as
far as I
>> > remember) deletes the GeoServer Data Dir.
>> > GeoServer Professional Services from the experts! Visit
>> > <http://goo.gl/NWWaa2> for more information.
>> > Ing. Alessio Fabiani
>> > @alfa7691
>> > Founder/Technical Lead
>> > GeoSolutions S.A.S.
>> > Via Poggio alle Viti 1187
>> > 55054  Massarosa (LU)
>> > Italy
>> > phone: +39 0584 962313
>> > fax:     +39 0584 1660272
>> > mob:   +39 331 6233686
>> > <http://www.geo-solutions.it>
>> > <http://twitter.com/geosolutions_it>
>> > AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> > Le informazioni contenute in questo messaggio di posta
elettronica e/o
>> > nel/i
>> > file/s allegato/i sono da considerarsi strettamente riservate.
Il loro
>> > utilizzo è consentito esclusivamente al destinatario del
messaggio, per
>> > le
>> > finalità indicate nel messaggio stesso. Qualora riceviate questo
>> > messaggio
>> > senza esserne il destinatario, Vi preghiamo cortesemente di
darcene
>> > notizia
>> > via e-mail e di procedere alla distruzione del messaggio stesso,
>> > cancellandolo dal Vostro sistema. Conservare il messaggio
stesso,
>> > divulgarlo
>> > anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo
>> > per
>> > finalità diverse, costituisce comportamento contrario ai
principi
>> > dettati
>> > dal D.Lgs. 196/2003.
>> > The information in this message and/or attachments, is intended
solely
>> > for
>> > the attention and use of the named addressee(s) and may be
confidential
>> > or
>> > proprietary in nature or covered by the provisions of privacy
act
>> > (Legislative Decree June, 30 2003, no.196 - Italy's New Data
Protection
>> > Code).Any use not in accord with its purpose, any disclosure,
>> > reproduction,
>> > copying, distribution, or either dissemination, either whole or
partial,
>> > is
>> > strictly forbidden except previous formal approval of the named
>> > addressee(s). If you are not the intended recipient, please
contact
>> > immediately the sender by telephone, fax or e-mail and delete
the
>> > information in this message that has been received in error. The
sender
>> > does
>> > not give any warranty or accept liability as the content,
accuracy or
>> > completeness of sent messages and accepts no responsibility  for
changes
>> > made after they were sent or for other risks which arise as a
result of
>> > e-mail transmission, viruses, etc.
>> > On Wed, Dec 2, 2015 at 3:20 PM, Ariel Nunez
>> > wrote:
>> >> I am also in favor of even/odd, and releasing a 2.4.1 with
bugfixes.
>> >> Alessio, we need to make sure that the new geoserver
artifact does not
>> >> wipe out the geoserver data dir on the user's computers. We
have tested
>> >> it
>> >> with the geonode debian package but I am not sure it works
on the
>> >> geoserver-geonode debian package.
>> >> Jeff, we talked about even/odd during the code sprint and
there seemed
>> >> to
>> >> be agreement in the room. But you are right that it has not
received
>> >> formal
>> >> voting. Can we use this thread for people to vote concerns
against it
>> >> or
>> >> support or should we do that in a github issue?
>> >> -a
>> >> On Wed, Dec 2, 2015 at 9:11 AM, Jeffrey Johnson
>> >> wrote:
>> >>> Note Im not sure we agreed to do the even/odd numbering.
Im in favor,
>> >>> but I think we may need some more discussion before
moving in this
>> >>> direction.
>> >>> On Wed, Dec 2, 2015 at 7:04 PM, Tom Kralidis
<[tomkralidis at gmail.com](mailto:tomkralidis at gmail.com)>
>> >>> wrote:
>> >>> > +1 for a 2.4 branch.  Note that at some point we
agreed on using the
>> >>> > even/odd strategy [1] for GeoNode releases, so our
next stable
>> >>> > release
>> >>> > would be 2.6 (bug fix releases would be .z, i.e.
2.4.1, etc.).
>> >>> > Comments?  Should we have this documented
somewhere?
>> >>> > ..Tom
>> >>> > [1]
#release-number-even-odd-strategy>
>> >>> > On Tue, 1 Dec 2015, Ariel Nunez wrote:
>> >>> >> Date: Tue, 1 Dec 2015 19:47:53 -0500
>> >>> >> From: Ariel Nunez
>> >>> >> To: Patrick Dufour
>> >>> >> Cc: geonode-devel <[geonode-
devel at lists.osgeo.org](mailto:geonode-devel at lists.osgeo.org)>
>> >>> >> Subject: Re: [GeoNode-devel] 2.4.x Branch
>> >>> >> I believe this is a good idea too.
>> >>> >> -a
>> >>> >> On Tue, Dec 1, 2015 at 3:04 PM, Patrick Dufour
>> >>> >> wrote:
>> >>> >>> We should create a 2.4.x branch on the main
GeoNode repo like we
>> >>> >>> have
>> >>> >>> for
>> >>> >>> 2.0.x.;  unless we have a different plan
underway to support 2.4
>> >>> >>> and
>> >>> >>> 2.5.
>> >>> >>> I did miss the road mapping day of the
recent GeoNode code sprint,
>> >>> >>> though.  My ideas might be out of date.
>> >>> >>> Thanks!
>> >>> >>> Regards,
>> >>> >>> Patrick Dufour
>> >>> > _______________________________________________
>> >>> > geonode-devel mailing list
>> >>> > [geonode-devel at lists.osgeo.org](mailto:geonode-
>> >>> > <http://lists.osgeo.org/mailman/listinfo/geonode-
devel>
>> >> <http://lists.osgeo.org/mailman/listinfo/geonode-devel>
>> Paolo Corti
>> Geospatial software developer
>> web: <http://www.paolocorti.net>
>> twitter: @capooti
>> skype: capooti
>> [geonode-devel at lists.osgeo.org](mailto:geonode-devel at lists.osgeo.org)
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160105/5408ddbc/attachment-0001.html>
More information about the geonode-devel mailing list
