[GeoNode-devel] [OSGeo-Discuss] Starting the build process for OSGeo-Live 9.5
Ariel Nunez ingenieroariel at gmail.com
Sun Jan 10 09:39:36 PST 2016
I just added you on Launchpad as an administrator.
Thanks Angelos!
-a
On Sun, Jan 10, 2016 at 12:14 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
wrote:
> Hi all and Happy New Year,
> I just finished porting the GeoNode OSGeo PPA to 2.4 final.
> The packages can be found here:
> https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/geonode/+packages
> Some details:
> 1. I removed all explicit dependencies to geoserver and postgis.
> 2. The configuration is done through a shell script:
> https://github.com/OSGeo/OSGeoLive/blob/master/bin/install_geonode.sh
> 3. The python-django package provided in our stable ppa is not done
> properly, the django-admin binary is missing. I backported django 1.6.11 to
> trusty here:
> https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/osgeolive/+sourcepub/5949521/+listing-archive-extra
> This new django package is not tested yet, will test in next OSGeoLive
> nightly build.
> So far, GeoNode 2.4 is working as expected in OSGeoLive nightly build15
> along with GeoServer 2.7.5 and django 1.6.1:
> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-build15-amd64-a341ee0.iso
> The issue regarding loading vector layers has been fixed! Will update the
> ticket.
> What would be the best way to proceed? Should we wipe out GeoNode OSGeo
> PPA or should we use another PPA? I would recommend to delete the GeoNode
> OSGeo PPA and re-create it with the new packages. Unfortunately I do not
> have permissions for this, can someone please add me to the maintenance
> team?
> Best,
> Angelos
> On Tue, Nov 24, 2015 at 3:29 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
> wrote:
>> Thanks Ariel for the feedback,
>> I will have some free time to work on this in about 2 weeks.
>> Best,
>> Angelos
>> On 11/24/2015 03:02 PM, Ariel Nunez wrote:
>>> We do not use "our" debian package for osgeo live, but all the
>>> dependencies
>>> are packaged as deb files. The python-geonode debian package is not the
>>> same as the geonode debian package, python-geonode does not do any
>>> configuration, just defines the python based dependencies and installs
>>> the
>>> python code.
>>> There is an installation script in the osgeo live dvd for GeoNode, it
>>> could
>>> use a template project or not, and it uses a shared apache server in
>>> there.
>>> The tasks to be done would be:
>>> 1. Copy all the new dependencies from stable to the osgeo ppa.
>>> 2. Create a new python-geonode package based on the current one in that
>>> ppa
>>> (download that package with apt-source and reuse the control file, use
>>> the
>>> geonode 2.4 artifact in pypi).
>>> 3. Run the osgeo live dvd with the updated packages
>>> 4. Look into the reported bug of layers not loading that is reported in
>>> the
>>> osgeo tracker, make a point release if any bug is found and fixed.
>>> 5. Rinse and repeat.
>>> Unfortunately, I do not have time in the next month to help with this,
>>> but
>>> I am happy to answer any questions about it.
>>> -a
>>> On Mon, Nov 23, 2015 at 11:18 AM, Jeffrey Johnson <ortelius at gmail.com>
>>> wrote:
>>> I wonder if we should go about this a bit differently and just run a
>>>> template project with swgi and not bother with packages, connecting to
>>>> the existing GeoServer. Ariel thoughts?
>>>> On Mon, Nov 23, 2015 at 8:12 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com
>>>> wrote:
>>>>> Cool, we should cherry-pick packages from stable ppa to the osgeo ppa
>>>> that
>>>>> Ariel setup some time ago.
>>>>> Then we need a modification in python-geonode not to pull the geoserver
>>>> deb
>>>>> file...
>>>>> On 11/23/2015 06:09 PM, Jeffrey Johnson wrote:
>>>>>> Sorry I missed it on Gitter during the sprint. I think we can go with
>>>>>> totally vanilla geoserver and just disable permissions completely from
>>>>>> the UI and do updatelayers with the local geoserver.
>>>>>> On Mon, Nov 23, 2015 at 8:06 AM, Angelos Tzotsos <
>>>>>> wrote:
>>>>>>> With some guidance from Ariel, I can try.
>>>>>>> We need to use vanilla geoserver (this is why I asked in gitter
>>>>>>> during
>>>>>>> the
>>>>>>> code sprint :)
>>>>>>> Best,
>>>>>>> Angelos
>>>>>>> On 11/23/2015 05:13 PM, Jeffrey Johnson wrote:
>>>>>>>> Are we going to try to upgrade the geonode on osgeolive? If so, who
>>>>>>>> has time to help with this?
>>>>>>>> On Sun, Nov 22, 2015 at 11:18 AM, Cameron Shorter
>>>>>>>> <cameron.shorter at gmail.com> wrote:
>>>>>>>>> We are starting the build cycle for version 9.5 of the OSGeo-Live
>>>>>>>>> [1]
>>>>>>>>> DVD/USB/VM which will be released in March 2016, ready for several
>>>>>>>>> special
>>>>>>>>> events, including FOSS4G-NA, FOSSGIS (Salzburg, Austria), among
>>>>>>>> others.
>>>>> We would like to hear from anyone wishing to add new projects to
>>>>>>>>> OSGeo-Live,
>>>>>>>>> anyone wishing to extend or add translations, or anyone who has
>>>>>>>>> ideas
>>>>>>>>> on
>>>>>>>>> how
>>>>>>>>> we should shape the upcoming release.
>>>>>>>>> Key Milestones
>>>>>>>>> 11 Jan 2016 All new applications installed, most old applications
>>>>>>>>> updated
>>>>>>>>> 01 Feb 2016 Feature Freeze (all apps updated)
>>>>>>>>> 15 Feb 2016 User Acceptance Test (all apps installed and working)
>>>>>>>>> 21 Mar 2016 Final ISO sent to printers
>>>>>>>>> About OSGeo-Live
>>>>>>>>> OSGeo-live is a Lubuntu based distribution of Geospatial Open
>>>>>>>>> Source
>>>>>>>>> Software, available via a Live DVD, Virtual Machine and USB. You
>>>>>>>>> can
>>>>>>>>> use
>>>>>>>>> OSGeo-Live to try a wide variety of open source geospatial software
>>>>>>>>> without
>>>>>>>>> installing anything.
>>>>>>>>> [1] http://live.osgeo.org
>>>>>>>>> Cameron Shorter,
>>>>>>>>> Software and Data Solutions Manager
>>>>>>>>> LISAsoft
>>>>>>>>> Suite 112, Jones Bay Wharf,
>>>>>>>>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>>>>>>>> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
>>>>>>>>> _______________________________________________
>>>>>>>>> Discuss mailing list
>>>>>>>>> Discuss at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/discuss
>>>>>>>> geonode-devel mailing list
>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>> Angelos Tzotsos, PhD
>>>>>>> OSGeo Charter Member
>>>>>>> http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160110/93a7723c/attachment-0001.html>
More information about the geonode-devel mailing list
