[GeoNode-devel] Django 1.9 compatibility
Ariel Nunez ingenieroariel at gmail.com
Tue Jan 12 06:17:53 PST 2016
Karma,
It boils to two things, imho:
1. Dependency on a lot of third party django packages means upgrading when
all those are upgraded or having to maintain forks.
2. Using Ubuntu LTS means waiting two years before jumping versions on the
production recommendations.
The actual issues found on each upgrade are usually not that bad and
require minor modifications to GeoNode's code base.
Now that we are in the area, do you know what the next Ubuntu LTS is
shipping with?
-a
On Tue, Jan 12, 2016 at 8:33 AM, Karma Kolabor <collaborista at gmail.com>
wrote:
> I would be very interested in reading more about the update / upgrade
> process - please make notes about the problematic areas and it would
> be very appreciated if you could publish your notes and how you got
> around the problems in a blog post or anything else.
> This is more about general problems with django in longterm projects -
> I see many project that seem to be stuck on old versions - I would
> like to find out more about the reasons for this phenomen.
> Thanks for your attention,
> Karma
> On Wed, Jan 6, 2016 at 10:22 AM, Simone Dalmasso
> <simone.dalmasso at gmail.com> wrote:
> > Hi.
> > I don't think that anyone has tried it yet. What kind of issues are you
> > facing? We are definitely interested in upgrading django and will try to
> > give you support.  Happy to receive PRs as well :)
> > Il martedì 5 gennaio 2016, Jiehua Chen <j at qed.ai> ha scritto:
> >> Hi all,
> >> Anyone worked on make geonode compatible with Django 1.9? We are also
> >> trying to do that.
> >> Best,
> >> Jiehua Chen, Ph.D.
> >> QED | http://qed.ai
> > Simone
> > geonode-devel mailing list
> > geonode-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160112/5fa3e08b/attachment.html>
More information about the geonode-devel mailing list
