[GeoNode-devel] AuthenticationServiceException: Communication with GeoNode failed Caused by: java.net.SocketTimeoutException: Read timed out
Ken Abryl Eleazar Salanio kasalanio at dream.upd.edu.ph
Mon Jan 18 01:09:42 PST 2016
Yep, I've edited the config.xml to specify the geonode base location. If
the location cannot be found, geoserver outputs a "Caused by:
java.net.UnknownHostException: <hostname>". However in this case, it's a
socket timeout. Geoserver sees the location, but cannot finish the
authentication. Is it possible that apache or java blocks the connection
until it times out?
On Mon, Jan 18, 2016 at 4:48 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi,
> yes is in the geoserver data
> dir/security/auth/geonodeAuthProvider/config.xml. There you have to put the
> Regards
> 2016-01-18 9:47 GMT+01:00 Ken Abryl Eleazar Salanio <
> kasalanio at dream.upd.edu.ph>:
>> WARN [geonode.security] - Error connecting to the GeoNode server for
>>> authentication purposes
>>> org.springframework.security.authentication.AuthenticationServiceException:
>>>     at
>>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:61)
>>>     at
>>> org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:57)
>>>     at
>>> org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:156)
>>>     at
>>> org.geonode.security.GeoNodeAnonymousProcessingFilter.doFilter(GeoNodeAnonymousProcessingFilter.java:63)
>>>     at
>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>>>     at
>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
>>>     at
>>> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
>>>     at
>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
>>>     at
>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
>>>     at
>>> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
>>>     at
>>>     at
>>> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:107)
>>>     at
>>>     at
>>>     at
>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>>     at
>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
>>>     at
>>>     at
>>>     at
>>>     at
>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>>>     at
>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
>>>     at
>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>     at
>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>>>     at
>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>>>     at
>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>>>     at
>>> org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
>>>     at
>>>     at
>>>     at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>     at
>>>     at
>>>     at
>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
>>>     at
>>>     at
>>>     at
>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>>>     at
>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>>>     at
>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>>>     at
>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>>>     at
>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>>>     at
>>> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>>>     at
>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>>>     at
>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>>>     at
>>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>>>     at
>>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>>     at
>>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>>>     at
>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>>     at
>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>>     at java.lang.Thread.run(Thread.java:745)
>>>     at java.net.SocketInputStream.socketRead0(Native Method)
>>>     at java.net.SocketInputStream.read(SocketInputStream.java:152)
>>>     at java.net.SocketInputStream.read(SocketInputStream.java:122)
>>>     at java.io.BufferedInputStream.fill(BufferedInputStream.java:235)
>>>     at java.io.BufferedInputStream.read(BufferedInputStream.java:254)
>>>     at
>>> org.apache.commons.httpclient.HttpParser.readRawLine(HttpParser.java:78)
>>>     at
>>> org.apache.commons.httpclient.HttpParser.readLine(HttpParser.java:106)
>>>     at
>>> org.apache.commons.httpclient.HttpConnection.readLine(HttpConnection.java:1116)
>>>     at
>>> org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.readLine(MultiThreadedHttpConnectionManager.java:1413)
>>>     at
>>> org.apache.commons.httpclient.HttpMethodBase.readStatusLine(HttpMethodBase.java:1973)
>>>     at
>>> org.apache.commons.httpclient.HttpMethodBase.readResponse(HttpMethodBase.java:1735)
>>>     at
>>> org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1098)
>>>     at
>>> org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398)
>>>     at
>>> org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
>>>     at
>>> org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
>>>     at
>>> org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
>>>     at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:70)
>>>     at
>>> org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:152)
>>>     at
>>> org.geonode.security.DefaultSecurityClient.authenticateAnonymous(DefaultSecurityClient.java:135)
>>>     at
>>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:48)
>>>     ... 47 more
>> My question is, what geonode URI does geoserver use for authentication,
>> so that I may check if it is being blocked somewhere? Thanks!
>> On Mon, Jan 18, 2016 at 4:45 PM, Ken Abryl Eleazar Salanio <
>> kasalanio at dream.upd.edu.ph> wrote:
>>> Hi, I've installed a development version of geonode and i'm running the
>>> geoserver using tomcat 7. It worked for quite a while but I've recently
>>> encountered this error and can't seem to debug it:
>>> Ken Abryl Eleazar S. Salanio
>>> *Computer Programmer III*
>>> *Data Archiving and Distribution Component*
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160118/c31c414d/attachment.html>
More information about the geonode-devel mailing list
