[GeoNode-devel] GeoNode Windows installer: looking for testers
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Jan 18 01:48:16 PST 2016
Dear all,
at this address
https://www.dropbox.com/s/ujclwt7mtu5zy87/GeoNode-2.4.exe?dl=0
you can find a first version of the GeoNode Windows installer.
The installer has been created using NSIS compiler and if it works fine it
will be part at the official GeoNode distribution and continuous build as a
result of the folowing GNIP:
https://github.com/GeoNode/geonode/issues/2375
The installer works by installing under a folder chosen by the user:
1. A 32bit version of JRE 1.8
2. A 32bit version of Python 2.7.10 with virtualenv and GDAL bindings
3. A 32bit version of Apache Tomcat 7.0.35 with GeoServer
4. A customized version of minimal WinLAMP with only the Apache HTTPD +
mod_wsgi
At the end of the installation you should be able to see:
1. A running service of Apache Tomcat for GeoServer
2. A running service of Apache HTTPD server for GeoNode
Your GeoNode installation will be available at:
http://localhost
Your GeoServer installation will be available at:
http://localhost/geoserver
No DB is installed on this version. The installation relies on the default
GeoNode settings.
It could be possible to optionally install also PostGIS in the future if
the community really needs it.
Also notice that the GeoNode will be configured to run in production mode
through the mod_wsgi and not in development mode through paver.
Please test it and report any feedbacks.
Very soon I will make available the NSIS source code too.
Best Regards,
Alessio Fabiani.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160118/ac6712c5/attachment-0001.html>
More information about the geonode-devel mailing list
