[GeoNode-devel] [GeoNode-users] GeoNode Windows installer: looking for testers
Daniel Victoria daniel.victoria at gmail.com
Mon Jan 18 04:04:48 PST 2016
Can't the geonode install use the python that comes with it? Isolate it
from any other installation?
Looking at virtualenv_setup.bat it calls python_env.bat which will set the
path. But in that file (python_env.bat) there is no mention of python...
Also, when I start a fresh comand line in wn7, I can get into python by
just issuing 'python' command. But after I run virtualenv_setup.bat, I
can't run python anymore in that cmd window
On Mon, Jan 18, 2016 at 9:49 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Oh, I see.
> Yes, if you have another Python installation it may conflict.
> Don't know exactly what is the best way to proceed here, maybe asking to
> the user if he wants to use its own Python installation? But this may lead
> to installation issues since we don't know how the user has configured
> Python.
> Any feedbacks welcome.
> Alessio.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Mon, Jan 18, 2016 at 12:45 PM, Daniel Victoria <
> daniel.victoria at gmail.com> wrote:
>> Bingo,
>> No pip and virtualenv.
>> My computer had some funny python installation problems because I mixed
>> ArcMap with python(XY) and OSGeo4W. I've removed python(xy). But I see in
>> windows environment that
>> GEONODE_PATHEXT=C:\GeoNode-2.4\Python27;C:\GeoNode-2.4\Python27\Scripts;C:\Program
>> Files (x86)\GDAL. It looks correct
>> Cheers
>> Daniel
>> On Mon, Jan 18, 2016 at 9:36 AM, Alessio Fabiani <
>>> Daniel,
>>> roger. Maybe the GeoNode environment did not correctly configured.
>>> In the windows "All Apps" menu shortcuts, under the voide "GeoNode-2.4"
>>> you should see the "GeoNode VirtualEnv Setup" link. Can you try to run
>>> this? It should start automatically during the installation process, but
>>> maybe it needed an internet connection or something went wrong during this
>>> step. If this works for you we catched the issue and I can try to debug it.
>>> Many thanks for you patient and help!
>>> Alessio.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Mon, Jan 18, 2016 at 12:28 PM, Daniel Victoria <
>>>> Apache is running. If I stop the service and try to connect to
>>>> localhost, firefox will tell that it can't connect. And when I start the
>>>> service, firefox will just keep on trying to connect, with no success. Our
>>>> network uses a proxy but I've disabled it when connecting to localhost. So
>>>> that should not be the problem.
>>>> The error log just keeps on getting bigger (9.5 Mb now). Don't
>>>> understand much but it conplains about ImportError: No module named site
>>>> (entire log is attached).
>>>> Cheers
>>>> Daniel
>>>> On Mon, Jan 18, 2016 at 9:15 AM, Alessio Fabiani <
>>>>> Thanks Daniel,
>>>>> can you please check if Apache HTTPD service has started correctly? If
>>>>> so can you try to see if in the $INSTALLDIR/Apache2/logs/error.log there is
>>>>> something related to the issue?
>>>>> Also, make a try by restarting the Apache HTTPD service.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Mon, Jan 18, 2016 at 12:12 PM, Daniel Victoria <
>>>>>> Dear Alessio,
>>>>>> That's great news. I believe it will help spread the use of geonode
>>>>>> to other niches...
>>>>>> Anyway, I downloaded and installed the package in my machine.
>>>>>> Installation went without a problem (no error screens). However, when I try
>>>>>> to connect to http://localhost, it just keeps on waiting for the
>>>>>> server response and nothing happens. I never see the GeoNode web page. I
>>>>>> also tried 127.0.0.1.
>>>>>> I'm not sure this is because I'm in a corporate domain and there
>>>>>> might be some security blocks or if the installation did not work out.
>>>>>> Later I'll try the installation on my personal computer. Meanwhile, if
>>>>>> you'd like to figure out what happened, I can run the necessary tests, just
>>>>>> give me the instructions as to what to do.
>>>>>> Cheers
>>>>>> Daniel
>>>>>> On Mon, Jan 18, 2016 at 7:48 AM, Alessio Fabiani <
>>>>>>> Dear all,
>>>>>>> at this address
>>>>>>> https://www.dropbox.com/s/ujclwt7mtu5zy87/GeoNode-2.4.exe?dl=0
>>>>>>> you can find a first version of the GeoNode Windows installer.
>>>>>>> The installer has been created using NSIS compiler and if it works
>>>>>>> fine it will be part at the official GeoNode distribution and continuous
>>>>>>> build as a result of the folowing GNIP:
>>>>>>> https://github.com/GeoNode/geonode/issues/2375
>>>>>>> The installer works by installing under a folder chosen by the user:
>>>>>>> 1. A 32bit version of JRE 1.8
>>>>>>> 2. A 32bit version of Python 2.7.10 with virtualenv and GDAL bindings
>>>>>>> 3. A 32bit version of Apache Tomcat 7.0.35 with GeoServer
>>>>>>> 4. A customized version of minimal WinLAMP with only the Apache
>>>>>>> HTTPD + mod_wsgi
>>>>>>> At the end of the installation you should be able to see:
>>>>>>> 1. A running service of Apache Tomcat for GeoServer
>>>>>>> 2. A running service of Apache HTTPD server for GeoNode
>>>>>>> Your GeoNode installation will be available at:
>>>>>>> http://localhost
>>>>>>> Your GeoServer installation will be available at:
>>>>>>> http://localhost/geoserver
>>>>>>> No DB is installed on this version. The installation relies on the
>>>>>>> default GeoNode settings.
>>>>>>> It could be possible to optionally install also PostGIS in the
>>>>>>> future if the community really needs it.
>>>>>>> Also notice that the GeoNode will be configured to run in production
>>>>>>> mode through the mod_wsgi and not in development mode through paver.
>>>>>>> Please test it and report any feedbacks.
>>>>>>> Very soon I will make available the NSIS source code too.
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160118/a8e9fe51/attachment-0001.html>
More information about the geonode-devel mailing list
