[GeoNode-devel] GeoNode Backup and Restore ... any clue on DJango serialization?
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Jan 25 04:17:32 PST 2016
About this issue,
attached you can find a log of an import for a Layer into a fresh DB.
It is quite strange, the issue seems to be related to the
"base_contactrole" relation.
In the log you can see ho the "resource_id" for the "base_link" is
correctly parsed while for the "base_contactrole" is NULL.
I suspect some issues on the GeoNode model definitions.
Any idea?
Thanks,
Alessio.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, Jan 22, 2016 at 6:01 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi Alessio,
> can you check if there is actually a resourcebase with that id into the db?
> the problem I see is that the id is assigned by the db so it may change
> unless the resurcebase sequence is restored to 0. but the there is the
> reference to the resourcebase into the layer,
> 2016-01-22 17:38 GMT+01:00 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>:
>> Taking a look into the logs, the first JSON is correct. The issue is on
>> the reloading of the base_contactrole dependency.
>> GeoServer Professional Services from the experts! Visit
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Fri, Jan 22, 2016 at 5:26 PM, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Dear list,
>>> working on the GeoNode Backup and Restore task I'm struggling with an
>>> issue while trying to deserialize data.
>>> Basically what I'm trying to do is dump the GeoNode fixtures as JSON
>>> files and trying to load them later on an empty (prepared) GeoNode DB.
>>> Now ... by playing a bit with the json outputs and load order I am able
>>> to restore almost all the fixtures, but I have an issue with the Layers,
>>> inherited from ResourceBases.
>>> I am able to restore succesfully the ResourceBases but whenever I try to
>>> deserialize a Layer I'm getting and error with the primary key.
>>> Using the default JSON like this:
>>>   "pk": 1,
>>>   "model": "layers.layer",
>>>   "fields": {
>>>     "styles": [
>>>       1
>>>     "store": "datastore",
>>>     "name": "san_andres_y_providencia_administrative",
>>>     "service": null,
>>>     "charset": "UTF-8",
>>>     "title_en": "San Andres Y Providencia Administrative",
>>>     "abstract_en": "No abstract provided",
>>>     "regions": [],
>>>     "typename": "geonode:san_andres_y_providencia_administrative",
>>>     "default_style": null,
>>>     "purpose_en": null,
>>>     "workspace": "geonode",
>>>     "upload_session": 9,
>>>     "supplemental_information_en": "No information provided",
>>>     "data_quality_statement_en": null,
>>>     "storeType": "dataStore",
>>>     "distribution_description_en": null,
>>>     "constraints_other_en": null
>>> I get an error message like: null violates constraint for "resource_id"
>>> If I try to modify the JSON like this:
>>>   "*resourcebase_ptr_id*": 1,
>>>   "fields": {
>>>     "styles": [
>>>       1
>>>     "service": null,
>>>     "charset": "UTF-8",
>>>     "regions": [],
>>>     "purpose_en": null,
>>> I get the following error:
>>> ResourceBase matching query does not exist.
>>> Any idea/help ?
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160125/b4249648/attachment-0001.html>
Type: application/json
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160125/b4249648/attachment-0001.json>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160125/b4249648/attachment-0001.obj>
More information about the geonode-devel mailing list
