[GeoNode-devel] GeoExplorer Custmoization - RE: [GeoNode-users] GeoNode-GeoExplorer advice
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jan 26 01:24:14 PST 2016
Cool, thanks David!
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, Jan 22, 2016 at 1:56 PM, David Alda Fernandez de Lezea <
dalda at hazi.eus> wrote:
> Hi,
> I resend this email from the users list as I wanted to work on some
> modifications on the GeoExplorer element and after a tough process I've
> finally managed to make the app run (Yeeeha!), but on the way I've found
> several errors that I detail below (in my case I only wanted to work with
> GeoExplorer so some of the solutions provided "avoid" those problems in
> some way):
> [ERROR]
> Failed to execute goal on project geoexplorer: Could not resolve
> dependencies for project org.opengeo:geoexplorer:jar:4-SNAPSHOT: Failure to
> find org.ringojs:ringojs:jar:0.8.1 in http://repo.opengeo.org/ was cached
> in the local repo.  http://repo.opengeo.org --> IT DOESN'T EXIST!
> [SOLUTION]
> Changed http://repo.opengeo.org/ for https://repo.boundlessgeo.com/main
> [ERROR]
> Can't get
> http://www.nacis.org/naturalearth/50m/cultural/ne_50m_admin_0_countries.zip
> to
> C:\Datos\Proyectos\42_GEONODE\opengeo-suite\suite\geoserver\data_dir\externals\suite-data\default\ne_50m_admin_0_countries.zip
> [SOLUTION]
> Edit the file
> suite\geoserver\data_dir\externals\suite-data\default\build.xml and comment
> the line in which appears the referenced file
>   <!--<property name="ne_base_url" value="
> http://www.nacis.org/naturalearth/50m/cultural"/>-->
> And change it for
> http://www.naturalearthdata.com/http//www.naturalearthdata.com/download/50m/cultural
> [ERROR]
>  suite-data\default\build.xml:31: Execute failed: java.io.IOException:
> Cannot run program "ogr2ogr" (in directory
> "C:\Datos\Proyectos\42_GEONODE\opengeo-suite\sui
> te\geoserver\data_dir\externals\suite-data\default\workspaces\usa\data"):
> Create Process error=2, El sistema no puede encontrar el archivo
> especificado around Ant part ...<ant
> dir="externals/suite-data/default"/>... @ 4:44 in C:\Dat
> os\Proyectos\42_GEONODE\opengeo-suite\suite\geoserver\data_dir\target\antrun\bui
> ld-main.xml
>         at
> org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor
> .java:212)
>         at
> .java:153)
>         at
> .java:145)
>         at
> org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProje
> ct(LifecycleModuleBuilder.java:116)
>         at
> ct(LifecycleModuleBuilder.java:80)
>         at
> org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThre
> adedBuilder.build(SingleThreadedBuilder.java:51)
>         at
> org.apache.maven.lifecycle.internal.LifecycleStarter.execute(Lifecycl
> eStarter.java:128)
>         at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
>         at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
>         at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
>         at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
>         at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
>         at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
>         at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>         at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
> java:62)
>         at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
> sorImpl.java:43)
>         at java.lang.reflect.Method.invoke(Method.java:483)
>         at
> org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Laun
> cher.java:289)
>         at
> org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.jav
> a:229)
>         at
> org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(La
> uncher.java:415)
>         at
> org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:
> 356)
> Don't ask me why but it seems that the ogr2ogr program could not be found.
> It's just a geoserver's data_dir related issue, so I skip it.
> [SOLUTION]
> Comment the block in which appears de <exec></exec> tags on line 31 , file
> opengeo-suite\suite\geoserver\data_dir\externals\suite-data\default\build.xml
> [ERROR] Failed to execute goal on project geowebcache: Could not resolve
> depende ncies for project org.opengeo:geowebcache:war:4-SNAPSHOT: Could not
> find artifac t org.geowebcache:geowebcache:war:1.5.1 in opengeo (
> https://repo.boundlessgeo.com/main/) -> [Help 1]
> [SOLUTION]
> As I only want to work with geoexplorer so I skip this module by executing
> the clean install with some extra parameters that exclude the project
> geowebcache
> mvn -X clean install -pl !geowebcache
> [ERROR]
> org.apache.maven.plugins:maven-antrun-plugin:1.7:run (default) on project
> geoexplorer: An Ant BuildException has occured: Java returned: -1 around
> Ant part ...<java fork="true" classname="org.ringojs.tools.launcher.Main"
> failonerror="true">... @ 40:84 in
> C:\Datos\Proyectos\42_GEONODE\opengeo-suite\suite\geoexplorer\target\antrun\build-main.xml
> org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute
> goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (default) on
> project geoexplorer: An Ant BuildException has occured: Java returned: -1
> around Ant part ...<java fork="true"
> classname="org.ringojs.tools.launcher.Main" failonerror="true">...
>    [java] Entry not found in assets: widgets/ClassificationPanel.js
> (C:\Datos\Proyectos\42_GEONODE\opengeo-suite\suite\geoexplorer\externals\buildkit\lib\buildkit\merge.js#85)
>      [java]     at
> C:\Datos\Proyectos\42_GEONODE\opengeo-suite\suite\geoexplorer\externals\buildkit\lib\buildkit\merge.js:85
> (anonymous)
>      [java]     at
> C:\Datos\Proyectos\42_GEONODE\opengeo-suite\suite\geoexplorer\externals\buildkit\lib\buildkit\merge.js:28
> (anonymous)
>      [java]     at
> C:\Datos\Proyectos\42_GEONODE\opengeo-suite\suite\geoexplorer\externals\buildkit\lib\buildkit\merge.js:99
> (anonymous)
>      [java]     at
> C:\Datos\Proyectos\42_GEONODE\opengeo-suite\suite\geoexplorer\externals\buildkit\lib\buildkit\merge.js:110
> (anonymous)
>      [java]     at
> C:\Datos\Proyectos\42_GEONODE\opengeo-suite\suite\geoexplorer\externals\buildkit\lib\buildkit\build.js:54
> (main)
>      [java]     at
> C:\Datos\Proyectos\42_GEONODE\opengeo-suite\suite\geoexplorer\externals\buildkit\lib\buildkit\build.js:73
>      [java]
> [SOLUTION]
> Remove reference in file suite\geoexplorer\buildjs.cfg references to
> The final command outputs BUILD SUCCESS
> [INFO] Executed tasks
> [INFO]
> [INFO] Reactor Summary:
> [INFO]
> [INFO] OpenGeo Suite ...................................... SUCCESS [
> 2.687 s] [INFO] OpenGeo Suite GeoServer ............................
> SUCCESS [  3.653 s] [INFO] OpenGeo Suite GeoServer Externals
> .................. SUCCESS [  4.670 s] [INFO] OpenGeo Suite GeoServer
> Extensions ................. SUCCESS [  5.633 s] [INFO] GeoServer Data
> Directory ........................... SUCCESS [01:08 min] [INFO] OpenGeo
> Suite GeoServer Web Application ............ SUCCESS [  2.172 s] [INFO]
> OpenGeo Suite GeoServer Web Demo Module ............ SUCCESS [  9.857 s]
> [INFO] OpenGeo Suite GeoServer Web Theme Module ........... SUCCESS [
> 4.774 s] [INFO] OpenGeo Suite GeoServer Web App Module .............
> SUCCESS [02:19 min] [INFO] OpenGeo Suite GeoExplorer
> .......................... SUCCESS [01:06 min] [INFO] OpenGeo Suite
> Dashboard ............................ SUCCESS [  2.296 s] [INFO] OpenGeo
> Suite Jetty Module ......................... SUCCESS [ 14.073 s] [INFO]
> OpenGeo Recipe Book ................................ SUCCESS [ 13.355 s]
> [INFO]
> [INFO] BUILD SUCCESS
> [INFO]
> [INFO] Total time: 05:37 min
> [INFO] Finished at: 2016-01-22T12:23:25+01:00 [INFO] Final Memory:
> 60M/406M [INFO]
> Now that everything is built, run the command "ant debug" inside the
> geoexplorer directory and open a web browser and go to
> http://localhost:9080/ . You'll now see the composer.
> So, finally, after having everything alright I'd like to know which
> files/folders should modify to add new functionalities and how to rebuild
> the lib.
> Hope this process could help someone else.
> Regards,
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> *********************  LEGE OHARRA   *******************   AVISOLEGAL
> *******************   DISCLAIMER   *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160126/dba058e7/attachment-0001.html>
More information about the geonode-devel mailing list
