[GeoNode-devel] Fixing Geonode master syncdb
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Jul 7 06:18:00 PDT 2016
Thanks Simone,
yes maybe have someone else able to release the packages would be useful,
otherwise all the work will be always loaded on the same shoulders.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, Jul 7, 2016 at 3:14 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi Alessio,
> I can do that as I have the enviro set up. Would be great if more of us
> have the rights to do that.
> There was a section in the docs explaining how to get to the point of
> being able to release geonode packages, can't find it anymore though.
> Anyway I will do today for those packages.
> 2016-07-07 15:06 GMT+02:00 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>:
>> Dear all,
>> accordingly to this issue
>> https://github.com/GeoNode/geonode/issues/2488
>> the DJango migrations arebroken due to the old versions of GeoNode
>> components
>> geonode_dialogos-0.4
>> geonode_agon_ratings-0.3.4
>> geonode_user_accounts-1.0.10
>> geonode_avatar-2.1.4
>> geonode_announcements-1.0.7
>> geonode_user_messages-0.1.2
>> I see the associated Pull Requests from Emanuele Tajariol have been
>> merged, but this won't be sufficient in order to let GeoNode working again.
>> We need to update the components versions, push the new packages into
>> pypi and update the GeoNoser Seup.py file with the new versions.
>> How can we do this? Is there an administrator who can help us issue the
>> new releases?
>> Best Regards,
>> Alessio Fabiani.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160707/9fc3c82a/attachment-0001.html>
More information about the geonode-devel mailing list
