[GeoNode-devel] Fixing Geonode master syncdb
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jul 8 00:44:59 PDT 2016
Dears, I pushed the packages and updated geonode but I don't have
permissions for geonode-users-messages @ariel can you give me rights?
2016-07-08 9:12 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> ok I'll take care of this today
> 2016-07-07 17:02 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
>> +1 on adding dan, alessio and sarah to be able to push on pypi
>> On Thu, Jul 7, 2016 at 7:58 AM, Daniel Berry <dberry at boundlessgeo.com>
>> wrote:
>>> We may want to open pypi up for others to push new updated versions,
>>> especially with the 2.5 and 2.6 releases coming up.
>>> Thoughts?
>>> Dan
>>> On Thu, Jul 7, 2016 at 8:06 AM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Dear all,
>>>> accordingly to this issue
>>>> https://github.com/GeoNode/geonode/issues/2488
>>>> the DJango migrations arebroken due to the old versions of GeoNode
>>>> components
>>>> geonode_dialogos-0.4
>>>> geonode_agon_ratings-0.3.4
>>>> geonode_user_accounts-1.0.10
>>>> geonode_avatar-2.1.4
>>>> geonode_announcements-1.0.7
>>>> geonode_user_messages-0.1.2
>>>> I see the associated Pull Requests from Emanuele Tajariol have been
>>>> merged, but this won't be sufficient in order to let GeoNode working again.
>>>> We need to update the components versions, push the new packages into
>>>> pypi and update the GeoNoser Seup.py file with the new versions.
>>>> How can we do this? Is there an administrator who can help us issue the
>>>> new releases?
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> GeoServer Professional Services from the experts!
>>>> Visit http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A
>>>> 55054  Massarosa (LU)
>>>> Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>> principi dettati dal D.Lgs. 196/2003.
>>>> The information in this message and/or attachments, is intended solely
>>>> for the attention and use of the named addressee(s) and may be confidential
>>>> or proprietary in nature or covered by the provisions of privacy act
>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>> strictly forbidden except previous formal approval of the named
>>>> addressee(s). If you are not the intended recipient, please contact
>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>> information in this message that has been received in error. The sender
>>>> does not give any warranty or accept liability as the content, accuracy or
>>>> completeness of sent messages and accepts no responsibility  for changes
>>>> made after they were sent or for other risks which arise as a result of
>>>> e-mail transmission, viruses, etc.
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> *Daniel Berry*
>>> Senior Software Engineer | Boundless
>>> 512-468-3946 (cell)
>>> @boundlessgeo
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160708/7c78059b/attachment.html>
More information about the geonode-devel mailing list
