[GeoNode-devel] Fixing Geonode master syncdb
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jul 8 00:46:18 PDT 2016
dan, sarah and alessio could you please give me your pypi username? thanks
2016-07-08 9:44 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Dears, I pushed the packages and updated geonode but I don't have
> permissions for geonode-users-messages @ariel can you give me rights?
> 2016-07-08 9:12 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> ok I'll take care of this today
>> 2016-07-07 17:02 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
>>> +1 on adding dan, alessio and sarah to be able to push on pypi
>>> On Thu, Jul 7, 2016 at 7:58 AM, Daniel Berry <dberry at boundlessgeo.com>
>>> wrote:
>>>> We may want to open pypi up for others to push new updated versions,
>>>> especially with the 2.5 and 2.6 releases coming up.
>>>> Thoughts?
>>>> Dan
>>>> On Thu, Jul 7, 2016 at 8:06 AM, Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>> Dear all,
>>>>> accordingly to this issue
>>>>> https://github.com/GeoNode/geonode/issues/2488
>>>>> the DJango migrations arebroken due to the old versions of GeoNode
>>>>> components
>>>>> geonode_dialogos-0.4
>>>>> geonode_agon_ratings-0.3.4
>>>>> geonode_user_accounts-1.0.10
>>>>> geonode_avatar-2.1.4
>>>>> geonode_announcements-1.0.7
>>>>> geonode_user_messages-0.1.2
>>>>> I see the associated Pull Requests from Emanuele Tajariol have been
>>>>> merged, but this won't be sufficient in order to let GeoNode working again.
>>>>> We need to update the components versions, push the new packages into
>>>>> pypi and update the GeoNoser Seup.py file with the new versions.
>>>>> How can we do this? Is there an administrator who can help us issue
>>>>> the new releases?
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> GeoServer Professional Services from the experts!
>>>>> Visit http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A
>>>>> 55054 Massarosa (LU)
>>>>> Italy
>>>>> phone: +39 0584 962313
>>>>> fax: +39 0584 1660272
>>>>> mob: +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>> The information in this message and/or attachments, is intended solely
>>>>> for the attention and use of the named addressee(s) and may be confidential
>>>>> or proprietary in nature or covered by the provisions of privacy act
>>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>>> strictly forbidden except previous formal approval of the named
>>>>> addressee(s). If you are not the intended recipient, please contact
>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>> information in this message that has been received in error. The sender
>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>> completeness of sent messages and accepts no responsibility for changes
>>>>> made after they were sent or for other risks which arise as a result of
>>>>> e-mail transmission, viruses, etc.
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> *Daniel Berry*
>>>> Senior Software Engineer | Boundless
>>>> 512-468-3946 (cell)
>>>> @boundlessgeo
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160708/44b8c719/attachment-0001.html>
More information about the geonode-devel
