[GeoNode-devel] Fixing Geonode master syncdb
Daniel Berry
dberry at boundlessgeo.com
Fri Jul 8 05:23:44 PDT 2016
dberry
On Fri, Jul 8, 2016 at 2:46 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> dan, sarah and alessio could you please give me your pypi username? thanks
> 2016-07-08 9:44 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Dears, I pushed the packages and updated geonode but I don't have
>> permissions for geonode-users-messages @ariel can you give me rights?
>> 2016-07-08 9:12 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> ok I'll take care of this today
>>> 2016-07-07 17:02 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
>>>> +1 on adding dan, alessio and sarah to be able to push on pypi
>>>> On Thu, Jul 7, 2016 at 7:58 AM, Daniel Berry <dberry at boundlessgeo.com>
>>>> wrote:
>>>>> We may want to open pypi up for others to push new updated versions,
>>>>> especially with the 2.5 and 2.6 releases coming up.
>>>>> Thoughts?
>>>>> Dan
>>>>> On Thu, Jul 7, 2016 at 8:06 AM, Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>> Dear all,
>>>>>> accordingly to this issue
>>>>>> https://github.com/GeoNode/geonode/issues/2488
>>>>>> the DJango migrations arebroken due to the old versions of GeoNode
>>>>>> components
>>>>>> geonode_dialogos-0.4
>>>>>> geonode_agon_ratings-0.3.4
>>>>>> geonode_user_accounts-1.0.10
>>>>>> geonode_avatar-2.1.4
>>>>>> geonode_announcements-1.0.7
>>>>>> geonode_user_messages-0.1.2
>>>>>> I see the associated Pull Requests from Emanuele Tajariol have been
>>>>>> merged, but this won't be sufficient in order to let GeoNode working again.
>>>>>> We need to update the components versions, push the new packages into
>>>>>> pypi and update the GeoNoser Seup.py file with the new versions.
>>>>>> How can we do this? Is there an administrator who can help us issue
>>>>>> the new releases?
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> GeoServer Professional Services from the experts!
>>>>>> Visit http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A
>>>>>> 55054 Massarosa (LU)
>>>>>> Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax: +39 0584 1660272
>>>>>> mob: +39 331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>> The information in this message and/or attachments, is intended
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>> information in this message that has been received in error. The sender
>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>> completeness of sent messages and accepts no responsibility for changes
>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>> e-mail transmission, viruses, etc.
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> *Daniel Berry*
>>>>> Senior Software Engineer | Boundless
>>>>> 512-468-3946 (cell)
>>>>> @boundlessgeo
>>> Simone
>> Simone
> Simone
*Daniel Berry*
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160708/a56816a7/attachment-0001.html>
More information about the geonode-devel
