[GeoNode-devel] Upgrade to GeoServer 2.9
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Jul 11 02:35:11 PDT 2016
Hello Erik,
thanks for your work.
Currently GeoNode requires
    <dependency>
      <groupId>org.opengeo.geoserver</groupId>
      <artifactId>gs-geogig</artifactId>
      <version>${gsgeogig.version}</version>
      <classifier>shaded-plugin</classifier>
   </dependency>
to build.
In order to move the thigs faster I currently did:
1. Pushed the gs-geogig JARs into the GeoSolutions public maven repository (
http://maven.geo-solutions.it)
Those should be pushed into the boundless webdav ones. I must admit that
currently is not quite clear to me how is the policy to publish community
plugins JARs automatically from the CI. Maybe they must be added to the
"communityRelease" profile, but I have to ask.
2. Since I didn't find any maven builder extension to create the shaded
JAR, I currently slightly modified the geoserver-geonode POM.XML as follows
    <!-- Updated geogit to geogig
    <dependency>
      <!-- classifier>shaded-plugin</classifier -->
      <!-- exclusions>
<exclusion><groupId>org.locationtech.geogig</groupId><artifactId>geogig-geotools</artifactId></exclusion>
<exclusion><groupId>org.locationtech.geogig</groupId><artifactId>geogig-core</artifactId></exclusion>
<exclusion><groupId>org.locationtech.geogig</groupId><artifactId>geogig-cli</artifactId></exclusion>
<exclusion><groupId>org.locationtech.geogig</groupId><artifactId>geogig-mongodb</artifactId></exclusion>
<exclusion><groupId>org.locationtech.geogig</groupId><artifactId>geogig-sqlite-xerial</artifactId></exclusion>
<exclusion><groupId>org.locationtech.geogig</groupId><artifactId>geogig-sqlite-core</artifactId></exclusion>
<exclusion><groupId>org.locationtech.geogig</groupId><artifactId>geogig-metrics</artifactId></exclusion>
<exclusion><groupId>org.locationtech.geogig</groupId><artifactId>geogig-bdbje</artifactId></exclusion>
<exclusion><groupId>org.locationtech.geogig</groupId><artifactId>geogig-web-api</artifactId></exclusion>
<exclusion><groupId>org.locationtech.geogig</groupId><artifactId>geogig-osm</artifactId></exclusion>
<exclusion><groupId>com.jolbox</groupId><artifactId>bonecp</artifactId></exclusion>
      </exclusions -->
    </dependency>
<dependency>
      <groupId>ch.qos.logback</groupId>
      <artifactId>logback-core</artifactId>
      <version>${logback.version}</version>
    </dependency>
    <dependency>
      <artifactId>logback-classic</artifactId>
    </dependency>
    <dependency>
      <version>${geogig.version}</version>
    </dependency>
    <dependency>
    </dependency>
    <dependency>
      <artifactId>geogig-datastore</artifactId>
    </dependency>
    <dependency>
    </dependency>
    <dependency>
    </dependency>
    <dependency>
      <artifactId>geogig-postgres</artifactId>
    </dependency>
    <dependency>
      <!-- required by gs-geogig but declares it as provided to avoid gt
version clashes -->
      <groupId>org.geotools.jdbc</groupId>
      <artifactId>gt-jdbc-spatialite</artifactId>
      <version>${geotools.version}</version>
    </dependency>
    <dependency>
version clashes -->
      <groupId>org.geotools</groupId>
      <artifactId>gt-geopkg</artifactId>
    </dependency>
The build is successfull and the tests too. Please let me know if I did
something wrong or if I forgot/missed something.
Again I guess this is a side-effect of the missing automatic build of the
gs-geogig plugin from the GeoServer Jenkins (unless in the past the shaded
JAR has been build and published manually by boundless itself).
Conclusions
The update to GeoServer 2.9 for the GeoNode extension is now working and is
ready to be pushed on.
My idea is to move on the process and in the meantime clarify and (if
needed) fix the two points above and eventually commit the changes after
the merge.
I look forward for you feedbacks/indications.
Thanks again,
-A.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Sat, Jul 9, 2016 at 6:57 AM, Erik Merkle <emerkle at boundlessgeo.com>
wrote:
> All,
> The GeoServer plugin for GeoGig has been merged into both the 2.9.x branch
> of GeoServer as well as the master branch (GeoServer 2.10). The GeoGig jars
> are on the Boundless repos as well. Hopefully this removes any GeoGig
> related roadblocks for the upgrade.
> ​Regards,
> Erik
> On Fri, Jul 8, 2016 at 9:14 AM, Erik Merkle <emerkle at boundlessgeo.com>
> wrote:
>> Alessio,
>> The latest stable GeoGig jars are already being pushed to the Boundless
>> repo here:
>> https://repo.boundlessgeo.com/snapshot
>> The 1.0-SNAPSHOT version is stable and what the plugin is using (the
>> plugin for GS 2.8 uses 1.0-SNAPSHOT and 2.9 and master will use the same
>> GeoGig 1.0-SNAPSHOT version as soon as I get the PRs merged). You can build
>> against the GeoGig jars by adding something like this to your POM:
>>     <dependency>
>>       <version>1.0-SNAPSHOT</version>
>>     </dependency>
>> There is also a Release Candidate version in the Boundless Artifactory
>> here:
>> https://repo.boundlessgeo.com/release
>> But the latest release is version 1.0-RC2, dated early April.
>> As for the plugin, I've got it all working for GS 2.9 and GS 2.10
>> (master), just need to finish up a few functional tests and the PRs will be
>> created.
>> ​Regards,
>>>> Erik
>> On Fri, Jul 8, 2016 at 2:41 AM, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Very good,
>>> thanks for your help.
>>> Is there a way to push the geogig jars on the boundless maven repo when
>>> ready too?
>>> Thenaks again and kind regards,
>>> -A.
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> http://twitter.com/geosolutions_it
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> On Fri, Jul 8, 2016 at 3:46 AM, Erik Merkle <emerkle at boundlessgeo.com>
>>> wrote:
>>>> I think I have the plugin for GeoGig ported over to GeoServer 2.9 and
>>>> master (2.10). I'm finishing up some testing on them and as soon as I'm
>>>> finished, I'll submit the PRs. Getting the plugin into the master branch on
>>>> GeoServer should keep the plugin from causing issues with upgrading to
>>>> GeoNode to use GeoServer 2.10, when that time comes.
>>>> Erik Merkle
>>>> On Thu, Jul 7, 2016 at 11:40 AM, Erik Merkle <emerkle at boundlessgeo.com>
>>>> wrote:
>>>>> All,
>>>>> I've started to look at getting the plugin for GeoGig ported over from
>>>>> GeoServer 2.8.x to 2.9.x. Most of the issues are related to the Wicket
>>>>> version changes and seem to be fairly easy to address. I hope to have it
>>>>> ported over soon and I'll update the mailing list with my progress.
>>>>> ​Regards,​
>>>>> Erik Merkle
>>>>> On Thu, Jul 7, 2016 at 9:44 AM, Jeffrey Johnson <ortelius at gmail.com>
>>>>> wrote:
>>>>>> +1 on moving to 2.9 with just a PR and ensuring the build works
>>>>>> properly on build.geonode.org
>>>>>> +100 to boundless and geosolutions coordinating on these issues :)
>>>>>> +1000 on moving to a default geoserver build that doesnt require this
>>>>>> plugin
>>>>>> On Thu, Jul 7, 2016 at 7:40 AM, Alessio Fabiani <
>>>>>>> Hi Daniel,
>>>>>>> we can discuss when you are available during our both working hours
>>>>>>> I guess. My timezone is Rome - Italy one.
>>>>>>> Thanks for your support.
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> On Thu, Jul 7, 2016 at 4:09 PM, Daniel Berry <
>>>>>>> dberry at boundlessgeo.com> wrote:
>>>>>>>> Alessio,
>>>>>>>> I would think an issue and PR would be sufficient. We should add
>>>>>>>> what new features or changes are included though.
>>>>>>>> regarding the following
>>>>>>>> "*We need boundless to fix geogig 2.9.x version which is currently
>>>>>>>> broken. We need geogig JARs to be pushed on a public maven repository,
>>>>>>>> otherwise GeoServer won't compile. Is there someone from boundless which
>>>>>>>> can eventually help us with this task?"*
>>>>>>>> We sure can, Erik Merkle is currently researching the level of
>>>>>>>> effort for GeoGig 2.9.x extension. This would be great if we
>>>>>>>> could include this in the GeoNode 2.5 release. Would you like to schedule a
>>>>>>>> time to discuss?
>>>>>>>> Respectfully,
>>>>>>>> Daniel Berry
>>>>>>>> On Thu, Jul 7, 2016 at 8:13 AM, Alessio Fabiani <
>>>>>>>>> Dear all,
>>>>>>>>> I managed to succesfully update the geoserver-genode-ext to the
>>>>>>>>> 2.9 version, but there are still two things to discuss:
>>>>>>>>> 1. Everyone is ok with this GeoServer version? Should we go
>>>>>>>>> through a GNIP or an issue and PR are sufficient?
>>>>>>>>> 2. We need boulndless to fix geogig 2.9.x version which is
>>>>>>>>> currently broken. We need geogid JARs to be pushed on a public maven
>>>>>>>>> repository, otherwise GeoServer won't compile. Is there someone from
>>>>>>>>> boundless which can eventually help us with this task?
>>>>>>>>> Best Regards,
>>>>>>>>> Alessio Fabiani.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Italy
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-devel mailing list
>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>> *Daniel Berry*
>>>>>>>> Senior Software Engineer | Boundless
>>>>>>>> 512-468-3946 (cell)
>>>>>>>> @boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160711/8f4ab413/attachment-0001.html>
More information about the geonode-devel mailing list
