[GeoNode-devel] Mapquest background not available in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jul 14 06:21:46 PDT 2016
Dears,
as you may have noticed since yesterday the MapQuest background is not
available anymore in GeoNode. The reason is a change of policy and the
direct access to the tiles is discontinued.
See here for more info
http://devblog.mapquest.com/2016/06/15/modernization-of-mapquest-results-in-changes-to-open-tile-access/
if you need to fix existing maps you can run the following commands, they
will put OSM as default background.
$ geonode shell
>>>*from geonode.maps.models import MapLayer
*>>>*MapLayer.objects.filter(name='osm').update(visibility=False)
*>>>*MapLayer.objects.filter(name='mapnik').update(visibility=True)*
For new maps you can edit the settings file and make OSM the default
visible background
https://github.com/GeoNode/geonode/commit/8cb080534e69c590c8864a2603b2ea1eca2e8a73#diff-244cdfc4e5e50d8ee9386be986629b6aR624
Hope this helps
If anyone has more info please comment in this thread
Ciao
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160714/f545ad71/attachment.html>
More information about the geonode-devel mailing list
