[GeoNode-devel] Geonode Developers
Patrick Dufour pjdufour.dev at gmail.com
Fri Jul 22 05:27:03 PDT 2016
Example of GeoJSON Jekyll template
Final
http://state-hiu.github.io/hiu.state.gov/products/products.json
Template
https://raw.githubusercontent.com/state-hiu/hiu.state.gov/gh-pages/products/products.json
Looks like it does not work with *.github.io urls,only github.com.  For
example.
https://render.githubusercontent.com/view/geojson?url=http://state-hiu.github.io/hiu.state.gov/products/products.json
Tom, for now, I'm +1 for your approach for a map, since the yaml/template
approach will require more coding effort.  The yaml/template approach would
help us render the providers in other "views" such as a table, so probably
where we should end up.
Regards,
Patrick
On Fri, Jul 22, 2016 at 7:40 AM, Tom Kralidis <tomkralidis at gmail.com> wrote:
> Patrick: thanks for the info.  Any examples of this?  Note that the
> proposed branch requires providers only update a single GeoJSON file
> directly on GitHub.
> I've since submitted a PR [1] which we can improve over time.
> ..Tom
> [1] https://github.com/GeoNode/geonode.github.com/pull/38/files
> On Thu, Jul 21, 2016 at 11:54 PM, Patrick Dufour <pjdufour.dev at gmail.com>
> wrote:
> > You can render a geojson file via a jekyll template from yaml posts
> files.
> > That way users only need to make posts (yaml front matter + markdown
> > content) instead of raw html.
> > Regards,
> > Patrick
> > On Jul 21, 2016 8:53 PM, "Jeffrey Johnson" <ortelius at gmail.com> wrote:
> >> +1
> >> On Thursday, July 21, 2016, Tom Kralidis <tomkralidis at gmail.com> wrote:
> >>> Oops forgot the branch!
> >>> https://github.com/tomkralidis/geonode.github.com/tree/providers
> >>> On Thu, Jul 21, 2016 at 8:50 PM, Tom Kralidis <tomkralidis at gmail.com>
> >>> wrote:
> >>> > I've created a branch which adds a provider page (lifting text from
> >>> > http://mapserver.org/community/service_providers.html) as well as a
> >>> > providers' map, the idea being getting a map overview of providers
> >>> > around the world, and clicking a point allows the user to click the
> >>> > provider link to the website/URL.
> >>> > The requirement would be foreach provider to provide:
> >>> > - company name
> >>> > - lat/long coordinates
> >>> > - URL
> >>> > Providers could then add their info via pull request by updating the
> >>> > providers/providers.geojson directly.
> >>> > Thoughts?  I can PR this if folks think it's a good idea.
> >>> > On Thu, Jul 21, 2016 at 5:23 PM, Patrick Dufour
> >>> > <pjdufour.dev at gmail.com> wrote:
> >>> >> I think this is a great idea and would come in handy a lot!  Maybe
> >>> >> also
> >>> >> include which countries they operate in, but might want to hold that
> >>> >> for
> >>> >> version 2.  Would be easy to implement something in Jekyll using
> posts
> >>> >> and
> >>> >> an index.html page.
> >>> >> https://github.com/GeoNode/geonode.github.com/tree/master/faqs
> >>> >> Regards,
> >>> >> Patrick
> >>> >> On Mon, Jun 27, 2016 at 5:24 AM, Simone Giannecchini
> >>> >> <simone.giannecchini at geo-solutions.it> wrote:
> >>> >>> I would add also:
> >>> >>> GeoSolutions http://www.geo-solutions.it
> >>> >>> Regards,
> >>> >>> Simone Giannecchini
> >>> >>> GeoServer Professional Services from the experts!
> >>> >>> Visit http://goo.gl/it488V for more information.
> >>> >>> Ing. Simone Giannecchini
> >>> >>> @simogeo
> >>> >>> Founder/Director
> >>> >>> GeoSolutions S.A.S.
> >>> >>> Via di Montramito 3/A
> >>> >>> 55054  Massarosa (LU)
> >>> >>> Italy
> >>> >>> phone: +39 0584 962313
> >>> >>> fax:     +39 0584 1660272
> >>> >>> mob:   +39 333 8128928
> >>> >>> http://twitter.com/geosolutions_it
> >>> >>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> >>> >>> Le informazioni contenute in questo messaggio di posta elettronica
> >>> >>> e/o
> >>> >>> nel/i file/s allegato/i sono da considerarsi strettamente
> riservate.
> >>> >>> Il loro utilizzo è consentito esclusivamente al destinatario del
> >>> >>> messaggio, per le finalità indicate nel messaggio stesso. Qualora
> >>> >>> riceviate questo messaggio senza esserne il destinatario, Vi
> >>> >>> preghiamo
> >>> >>> cortesemente di darcene notizia via e-mail e di procedere alla
> >>> >>> distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
> >>> >>> Conservare il messaggio stesso, divulgarlo anche in parte,
> >>> >>> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità
> >>> >>> diverse, costituisce comportamento contrario ai principi dettati
> dal
> >>> >>> D.Lgs. 196/2003.
> >>> >>> The information in this message and/or attachments, is intended
> >>> >>> solely
> >>> >>> for the attention and use of the named addressee(s) and may be
> >>> >>> confidential or proprietary in nature or covered by the provisions
> of
> >>> >>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
> >>> >>> Data Protection Code).Any use not in accord with its purpose, any
> >>> >>> disclosure, reproduction, copying, distribution, or either
> >>> >>> dissemination, either whole or partial, is strictly forbidden
> except
> >>> >>> previous formal approval of the named addressee(s). If you are not
> >>> >>> the
> >>> >>> intended recipient, please contact immediately the sender by
> >>> >>> telephone, fax or e-mail and delete the information in this message
> >>> >>> that has been received in error. The sender does not give any
> >>> >>> warranty
> >>> >>> or accept liability as the content, accuracy or completeness of
> sent
> >>> >>> messages and accepts no responsibility  for changes made after they
> >>> >>> were sent or for other risks which arise as a result of e-mail
> >>> >>> transmission, viruses, etc.
> >>> >>> On Fri, Jun 10, 2016 at 10:40 PM, Jeffrey Johnson
> >>> >>> wrote:
> >>> >>> > James,
> >>> >>> > We keep discussing adding a page to the website with commercial
> >>> >>> > providers, but haven't ever done it. There are actually a bunch
> >>> >>> > these
> >>> >>> > days. A partial list is below (in no particular order).
> >>> >>> > If I am missing anyone (or you dont want to be included on future
> >>> >>> > versions of this list) please let me know.
> >>> >>> > If someone is up for making a page out of this on the site, send
> a
> >>> >>> > PR
> >>> >>> > and we can merge it.
> >>> >>> > Gesp http://www.gesp.it
> >>> >>> > AllSpatial https://github.com/allspatial (Michael Wagner)
> >>> >>> > LTS International http://www.ltsi.co.uk/
> >>> >>> > Prominent Edge http://prominentedge.com/
> >>> >>> > Piensa http://piensa.co/
> >>> >>> > ADPC http://adpc.net
> >>> >>> > Terranodo http://terranodo.io (full disclosure, this is my
> company)
> >>> >>> > AcuGIS https://www.acugis.com/
> >>> >>> > Kartoza http://kartoza.com/
> >>> >>> > Geo Enviro Omega http://www.geo.co.id/
> >>> >>> > Applied GeoSolutions http://www.appgeo.com/
> >>> >>> > Boundless http://boundlessgeo.com/
> >>> >>> > Agrisoft http://www.agrisoft.co.id/
> >>> >>> > Team Geode Belgium http://opengeode.be/
> >>> >>> > Geocent http://www.geocent.com/
> >>> >>> > Quantitative Engineering Design http://qed.ai
> >>> >>> > Note, Im sure there are plenty of individual developers on this
> >>> >>> > list
> >>> >>> > who could also help you.
> >>> >>> > Hope that helps!
> >>> >>> > Jeff
> >>> >>> > On Fri, Jun 10, 2016 at 12:58 PM, James Adamson
> >>> >>> > <james at northwaterco.com>
> >>> >>> > wrote:
> >>> >>> >> How would I go about finding a programmer/developer that I can
> >>> >>> >> work
> >>> >>> >> with to
> >>> >>> >> design and implement an GeoNode supported site?
> >>> >>> >> _____________
> >>> >>> >> James K. Adamson, P.G.
> >>> >>> >> +1.630.742.6836
> >>> >>> >> www.northwaterco.com
> >>> >>> >> _______________________________________________
> >>> >>> >> geonode-devel mailing list
> >>> >>> >> geonode-devel at lists.osgeo.org
> >>> >>> >> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160722/d9789b5e/attachment-0001.html>
More information about the geonode-devel mailing list
