[GeoNode-devel] QueryBuilder for Download Layer functionality
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jun 8 01:20:33 PDT 2016
Well, first of all it does not allow to filter raster layers, secondly the
filter could be potentially too big and finally it allow you just to filter
out subsets of data.
Everything works fine until you have small datasets and you don need to
crop and reproject the outcomes.
Finally, as far as I understood, everything is done synchronously. In other
words you lock the server until the request has finished. Again, it works
well until you have elatively small vectorial datasets.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Tue, Jun 7, 2016 at 8:53 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Hello Alessio
> On Fri, Jun 3, 2016 at 9:11 AM, Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Maybe you want to consider the use of such plugin to extend the
> capabilities
> > of your query plugin instead of relying only on CQL filters (if I
> understood
> > correctly how the tool currently works).
> Would love to learn what is wrong in relying on CQL filters
> thanks a lot
> p
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160608/397d64b7/attachment.html>
More information about the geonode-devel mailing list
