[GeoNode-devel] developer setup
Paolo Corti pcorti at gmail.com
Fri Jun 17 07:34:44 PDT 2016
Hi developers
I am trying to install geonode from master (I haven't done this since
2.4 was released). I am wondering which is the way to setup a
developer geonode instance.
Once it was possible, following this instructions [1], to generate an
environment using paver setup, which was taking care of the database
initial sync.
Now setup just set geoserver.
If I try to create the database, I get this error:
  Applying contenttypes.0001_initial...Traceback (most recent call last):
  File "./manage.py", line 29, in <module>
    execute_from_command_line(sys.argv)
  File "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
    utility.execute()
line 346, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/base.py",
line 394, in run_from_argv
    self.execute(*args, **cmd_options)
line 445, in execute
    output = self.handle(*args, **options)
  File "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/commands/migrate.py",
line 222, in handle
    executor.migrate(targets, plan, fake=fake, fake_initial=fake_initial)
  File "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/executor.py",
line 110, in migrate
    self.apply_migration(states[migration], migration, fake=fake,
line 148, in apply_migration
    state = migration.apply(state, schema_editor)
  File "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/migration.py",
line 115, in apply
    operation.database_forwards(self.app_label, schema_editor,
old_state, project_state)
  File "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/operations/models.py",
line 59, in database_forwards
    schema_editor.create_model(model)
  File "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/base/schema.py",
line 286, in create_model
    self.execute(sql, params or None)
line 111, in execute
    cursor.execute(sql, params)
  File "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/utils.py",
line 79, in execute
    return super(CursorDebugWrapper, self).execute(sql, params)
line 64, in execute
    return self.cursor.execute(sql, params)
  File "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/utils.py",
line 98, in __exit__
    six.reraise(dj_exc_type, dj_exc_value, traceback)
line 62, in execute
    return self.cursor.execute(sql)
django.db.utils.ProgrammingError: relation "django_content_type" already exists
I believe it is also important to always keep documentation updated.
thanks
p
[1] https://github.com/GeoNode/geonode
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
