[GeoNode-devel] developer setup
Paolo Corti pcorti at gmail.com
Fri Jun 17 07:56:33 PDT 2016
Actually it was my fault. I had a local_settings.pyc file still in the
directory which caused confusion.
No need to migrate auth (how could be that done if the database is not
existing?), just running syncdb works well.
Any reason not to run syncdb in paver setup as it was done once?
cheers
p
On Fri, Jun 17, 2016 at 10:43 AM, Ariel Nunez <ingenieroariel at gmail.com> wrote:
> Paolo, the way to do it is to first do a migrate auth and after that you can
> do a regular syncdb.
> python manage.py migrate auth
> python manage.py syncdb
> Not sure if that can be avoided - it seems a bit weird to me that a regular
> syncdb would not work.
> -a
> On Fri, Jun 17, 2016 at 9:40 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> It seems that from Django 1.8 it is needed to run migrate with the
>> --fake-initial settings
>> (http://stackoverflow.com/questions/29760817/how-can-i-resolve-django-content-type-already-exists)
>> Though, I am now getting a different error:
>> Applying layers.0001_initial...Traceback (most recent call last):
>> django.db.utils.ProgrammingError: relation "layers_attribute" already
>> exists
>> p
>> On Fri, Jun 17, 2016 at 10:34 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> > Hi developers
>> > I am trying to install geonode from master (I haven't done this since
>> > 2.4 was released). I am wondering which is the way to setup a
>> > developer geonode instance.
>> > Once it was possible, following this instructions [1], to generate an
>> > environment using paver setup, which was taking care of the database
>> > initial sync.
>> > Now setup just set geoserver.
>> > If I try to create the database, I get this error:
>> >   Applying contenttypes.0001_initial...Traceback (most recent call
>> > last):
>> >   File "./manage.py", line 29, in <module>
>> >     execute_from_command_line(sys.argv)
>> >   File
>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>> > line 354, in execute_from_command_line
>> >     utility.execute()
>> >   File
>> > line 346, in execute
>> >     self.fetch_command(subcommand).run_from_argv(self.argv)
>> >   File
>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/base.py",
>> > line 394, in run_from_argv
>> >     self.execute(*args, **cmd_options)
>> >   File
>> > line 445, in execute
>> >     output = self.handle(*args, **options)
>> >   File
>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/commands/migrate.py",
>> > line 222, in handle
>> >     executor.migrate(targets, plan, fake=fake,
>> > fake_initial=fake_initial)
>> >   File
>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/executor.py",
>> > line 110, in migrate
>> >     self.apply_migration(states[migration], migration, fake=fake,
>> >   File
>> > line 148, in apply_migration
>> >     state = migration.apply(state, schema_editor)
>> >   File
>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/migration.py",
>> > line 115, in apply
>> >     operation.database_forwards(self.app_label, schema_editor,
>> > old_state, project_state)
>> >   File
>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/operations/models.py",
>> > line 59, in database_forwards
>> >     schema_editor.create_model(model)
>> >   File
>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/base/schema.py",
>> > line 286, in create_model
>> >     self.execute(sql, params or None)
>> >   File
>> > line 111, in execute
>> >     cursor.execute(sql, params)
>> >   File
>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/utils.py",
>> > line 79, in execute
>> >     return super(CursorDebugWrapper, self).execute(sql, params)
>> >   File
>> > line 64, in execute
>> >     return self.cursor.execute(sql, params)
>> >   File
>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/utils.py",
>> > line 98, in __exit__
>> >     six.reraise(dj_exc_type, dj_exc_value, traceback)
>> >   File
>> > line 62, in execute
>> >     return self.cursor.execute(sql)
>> > django.db.utils.ProgrammingError: relation "django_content_type" already
>> > exists
>> > I believe it is also important to always keep documentation updated.
>> > thanks
>> > p
>> > [1] https://github.com/GeoNode/geonode
>> > Paolo Corti
>> > Geospatial software developer
>> > web: http://www.paolocorti.net
>> > twitter: @capooti
>> > skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
