[GeoNode-devel] Uploading layer hangs at: Performing Final GeoServer Config Step
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 24 04:31:15 PDT 2016
Than is not that the issue. Other thing it could be is a communication
issue between geonode and geoserver which could lead to "no such layer".
Does geoserver correctly keeps the login from geonode when you access
"/geoserver" or "localhost:8080/geoserver"?
2016-06-24 12:07 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
> It is being done in a VM with 4 cores, and 8Gig of RAM.
> the Xms and Xmx values for tomcat are 4096m.
> How may i provide the aditional resources to geoserver?
> May Yahweh bless you and keep you.
> May Yahweh let his face shine on you and be gracious to you.
> May Yahweh show you his face and bring you peace.
> (New Jerusalem Bible Numbers 6:24-26)
> email: marcathian at gmail.com
> Home: 453-3632 / 453-3454
> Mobile: 719-2248
> Work: 468-4434
> On Fri, Jun 24, 2016 at 3:27 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi, could it be that your machine is not powerful enough? Seems that
>> geoserver has not enough resources to process the layer in reasonable time.
>> 2016-06-24 2:18 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
>>> Hello;
>>> I am preparing to deploy a geonode installation using GeoNode version
>>> 2.4.dev20160527174840.
>>> When attempting to upload an esri shp file through the upload layers
>>> page the process hangs at the message: performing Final GeoServer Config
>>> Step.
>>> I shall be grateful for assistance in resolving the issue.  The content
>>> of the logs are below.
>>> output from the postgresql log:
>>> 2016-06-23 18:44:40 AST [5406-25] geonode at geonode WARNING:  01000:
>>> ST_Force_2d signature was deprecated in 2.1.0. Please use ST_Force2D
>>> 2016-06-23 18:44:40 AST [5406-26] geonode at geonode CONTEXT:  SQL
>>> function "st_force_2d" during startup
>>> 2016-06-23 18:44:40 AST [5406-27] geonode at geonode LOCATION:
>>>  exec_stmt_raise, pl_exec.c:3216
>>> 2016-06-23 18:44:40 AST [5406-28] geonode at geonode STATEMENT:  SELECT
>>> ST_AsText(ST_Force_2D(ST_Envelope(ST_Extent("the_geom"::geometry)))) FROM
>>> "public"."West_Highway"
>>> 2016-06-23 18:44:46 AST [5406-29] geonode at geonode WARNING:  01000:
>>> 2016-06-23 18:44:46 AST [5406-30] geonode at geonode CONTEXT:  SQL
>>> 2016-06-23 18:44:46 AST [5406-31] geonode at geonode LOCATION:
>>> 2016-06-23 18:44:46 AST [5406-32] geonode at geonode STATEMENT:  SELECT
>>> "fid",encode(ST_AsBinary(ST_Force_2D("the_geom")),'base64') as "the_geom"
>>> FROM "public"."West_Highway" WHERE  "the_geom" && ST_GeomFromText('POLYGON
>>> ((487266.2853154304 1518248.9631568347, 487266.2853154304
>>> 1546225.3912784152, 524325.9693206407 1546225.3912784152, 524325.9693206407
>>> 1518248.9631568347, 487266.2853154304 1518248.9631568347))', 2006) AND
>>> ST_Intersects("the_geom", ST_GeomFromText('POLYGON ((487266.2853154304
>>> 1518248.9631568347, 487266.2853154304 1546225.3912784152, 524325.9693206407
>>> 1546225.3912784152, 524325.9693206407 1518248.9631568347, 487266.2853154304
>>> 1518248.9631568347))', 2006))
>>> Output from TomCat7 log:
>>> Jun 23, 2016 6:44:40 PM org.geoserver.importer.rest.TaskResource
>>> handlePost
>>> INFO: Handling POST of multipart/form-data;
>>> boundary=----------ThIs_Is_tHe_bouNdaRY_$
>>> 23 Jun 18:44:40 WARN [geoserver.security] - Could not find factory for
>>> store : DataStoreInfoImpl[datastore]. Unable to encrypt connection
>>> parameters.
>>> 23 Jun 18:44:40 INFO [org.geoserver] - Loaded store 'datastore', enabled
>>> 23 Jun 18:44:40 INFO [geoserver.importer] - begining import
>>> 23 Jun 18:44:40 ERROR [geoserver.rest] - No such layer: West_Highway
>>> org.geoserver.rest.RestletException
>>> at org.geoserver.catalog.rest.LayerFinder.findTarget(LayerFinder.java:39)
>>> at org.restlet.Finder.handle(Finder.java:268)
>>> at
>>> org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
>>> at org.restlet.Filter.doHandle(Filter.java:105)
>>> at org.restlet.Filter.handle(Filter.java:134)
>>> at org.restlet.Router.handle(Router.java:444)
>>> at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
>>> at
>>> com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
>>> at
>>> org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
>>> at
>>> org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
>>> at
>>> org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
>>> at
>>> org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
>>> at
>>> org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
>>> at
>>> org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
>>> at
>>> org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
>>> at
>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
>>> at
>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>>> at
>>> org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
>>> at
>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>>> at
>>> at
>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
>>> at
>>> org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
>>> at
>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
>>> at
>>> org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
>>> at
>>> at
>>> at
>>> org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
>>> at
>>> at
>>> at
>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
>>> at
>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>> at
>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
>>> at
>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
>>> at
>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>> at
>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
>>> at
>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>>> at
>>> at
>>> org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
>>> at
>>> at
>>> at
>>> at
>>> org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
>>> at
>>> at
>>> at
>>> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
>>> at
>>> at
>>> at
>>> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
>>> at
>>> at
>>> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:111)
>>> at
>>> at
>>> at
>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>> at
>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
>>> at
>>> at
>>> at
>>> at
>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>>> at
>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
>>> at
>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>> at
>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>>> at
>>> at
>>> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
>>> at
>>> at
>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>> at
>>> at
>>> at
>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
>>> at
>>> at
>>> at
>>> org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
>>> at
>>> at
>>> at
>>> org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
>>> at
>>> at
>>> at
>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>>> at
>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>>> at
>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>>> at
>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>>> at
>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>>> at
>>> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>>> at
>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>>> at
>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>>> at
>>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>>> at
>>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>> at
>>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>>> at
>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>> at
>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>> at java.lang.Thread.run(Thread.java:745)
>>> 23 Jun 18:44:40 INFO [geoserver.importer] - load to target took 104
>>> 23 Jun 18:44:45 INFO [org.geoserver] - Loaded feature type 'null',
>>> enabled
>>> 23 Jun 18:44:45 WARN [catalog.impl] - Failed to load actual store for
>>> FeatureTypeInfoImpl[null]
>>> 23 Jun 18:44:45 INFO [catalog.rest] - PUT
>>> FeatureTypedatastore,West_Highway updated metadata only
>>> 23 Jun 18:44:46 INFO [geoserver.wms] -
>>> Request: getServiceInfo
>>> Request: reflect
>>> SldBody = null
>>> ValidateSchema = false
>>> Sld = null
>>> StyleUrl = null
>>> Width = 200
>>> Height = 150
>>> Interpolations = []
>>> StyleFormat = sld
>>> Transparent = false
>>> TilesOrigin = null
>>> Tiled = false
>>> Palette = null
>>> FeatureVersion = null
>>> SRS = null
>>> Styles = [StyleImpl[ name=geonode_West_Highway1]]
>>> Layers = [org.geoserver.wms.MapLayerInfo at 1ee3d97d]
>>> MaxFeatures = null
>>> Crs = null
>>> Bbox = null
>>> RemoteOwsType = null
>>> RemoteOwsURL = null
>>> Env = {}
>>> FormatOptions = {}
>>> Angle = 0.0
>>> CQLFilter = null
>>> Elevation = []
>>> FeatureId = null
>>> StartIndex = null
>>> ViewParams = null
>>> BgColor = java.awt.Color[r=255,g=255,b=255]
>>> Exceptions = SE_XML
>>> StyleBody = null
>>> SldVersion = null
>>> StyleVersion = null
>>> ScaleMethod = null
>>> Format = image/png8
>>> Buffer = 0
>>> Time = []
>>> Filter = null
>>> Filters = null
>>> Get = true
>>> BaseUrl = http://sling.gosl.gov.lc:8080/geoserver/
>>> RawKvp = {FORMAT=image/png8, HEIGHT=150, LAYERS=geonode:West_Highway,
>>> WIDTH=200}
>>> RequestCharset = UTF-8
>>> Version = null
>>> Request = GetMap
>>> Mobile: 719-2248
>>> Work: 468-4434
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160624/b156101b/attachment-0001.html>
More information about the geonode-devel mailing list
