[GeoNode-devel] Uploading layer hangs at: Performing Final GeoServer Config Step
Marcathian Alexander marcathian at gmail.com
Fri Jun 24 08:54:03 PDT 2016
Thanks again Simone.
I have corrected the entry in the geoserver data
dir/security/auth/geonodeAuthProvider/config.xml; and the geoserver now
keeps the login from geonode.
However; the upload still hangs in the same place as initially reported.
What has also been happening is that the data makes its way into geoserver
and is visible from geoserver as a layer. but it will not be visible in
geonode until the update layers command is run and then the output of the
command will say that the layer has been created. at that point the layer
is visible in geonode.
May Yahweh bless you and keep you.
May Yahweh let his face shine on you and be gracious to you.
May Yahweh show you his face and bring you peace.
(New Jerusalem Bible Numbers 6:24-26)
email: marcathian at gmail.com
Home: 453-3632 / 453-3454
Mobile: 719-2248
Work: 468-4434
On Fri, Jun 24, 2016 at 9:15 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> You need to tell geoserver where to correctly find geonode. In the
> geoserver data dir/security/auth/geonodeAuthProvider/config.xml you can set
> the correct url of your geonode, then restart tomcat.
> 2016-06-24 15:12 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
>> Hello Simone;
>> Thanks for your assistance so far.
>> The login from geonode is not kept when the /geoserver is accessed.
>> I have to login again to the geoserver.
>> How do I resolve this?
>> Mobile: 719-2248
>> Work: 468-4434
>> On Fri, Jun 24, 2016 at 7:31 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Than is not that the issue. Other thing it could be is a communication
>>> issue between geonode and geoserver which could lead to "no such layer".
>>> Does geoserver correctly keeps the login from geonode when you access
>>> "/geoserver" or "localhost:8080/geoserver"?
>>> 2016-06-24 12:07 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
>>>> It is being done in a VM with 4 cores, and 8Gig of RAM.
>>>> the Xms and Xmx values for tomcat are 4096m.
>>>> How may i provide the aditional resources to geoserver?
>>>> Mobile: 719-2248
>>>> Work: 468-4434
>>>> On Fri, Jun 24, 2016 at 3:27 AM, Simone Dalmasso <
>>>>> Hi, could it be that your machine is not powerful enough? Seems that
>>>>> geoserver has not enough resources to process the layer in reasonable time.
>>>>> 2016-06-24 2:18 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
>>>>>> Hello;
>>>>>> I am preparing to deploy a geonode installation using GeoNode version
>>>>>> 2.4.dev20160527174840.
>>>>>> When attempting to upload an esri shp file through the upload layers
>>>>>> page the process hangs at the message: performing Final GeoServer Config
>>>>>> Step.
>>>>>> I shall be grateful for assistance in resolving the issue.  The
>>>>>> content of the logs are below.
>>>>>> output from the postgresql log:
>>>>>> 2016-06-23 18:44:40 AST [5406-25] geonode at geonode WARNING:  01000:
>>>>>> ST_Force_2d signature was deprecated in 2.1.0. Please use ST_Force2D
>>>>>> 2016-06-23 18:44:40 AST [5406-26] geonode at geonode CONTEXT:  SQL
>>>>>> function "st_force_2d" during startup
>>>>>> 2016-06-23 18:44:40 AST [5406-27] geonode at geonode LOCATION:
>>>>>>  exec_stmt_raise, pl_exec.c:3216
>>>>>> 2016-06-23 18:44:40 AST [5406-28] geonode at geonode STATEMENT:  SELECT
>>>>>> ST_AsText(ST_Force_2D(ST_Envelope(ST_Extent("the_geom"::geometry)))) FROM
>>>>>> "public"."West_Highway"
>>>>>> 2016-06-23 18:44:46 AST [5406-29] geonode at geonode WARNING:  01000:
>>>>>> 2016-06-23 18:44:46 AST [5406-30] geonode at geonode CONTEXT:  SQL
>>>>>> 2016-06-23 18:44:46 AST [5406-31] geonode at geonode LOCATION:
>>>>>> 2016-06-23 18:44:46 AST [5406-32] geonode at geonode STATEMENT:  SELECT
>>>>>> "fid",encode(ST_AsBinary(ST_Force_2D("the_geom")),'base64') as "the_geom"
>>>>>> FROM "public"."West_Highway" WHERE  "the_geom" && ST_GeomFromText('POLYGON
>>>>>> ((487266.2853154304 1518248.9631568347, 487266.2853154304
>>>>>> 1546225.3912784152, 524325.9693206407 1546225.3912784152, 524325.9693206407
>>>>>> 1518248.9631568347, 487266.2853154304 1518248.9631568347))', 2006) AND
>>>>>> ST_Intersects("the_geom", ST_GeomFromText('POLYGON ((487266.2853154304
>>>>>> 1518248.9631568347, 487266.2853154304 1546225.3912784152, 524325.9693206407
>>>>>> 1546225.3912784152, 524325.9693206407 1518248.9631568347, 487266.2853154304
>>>>>> 1518248.9631568347))', 2006))
>>>>>> Output from TomCat7 log:
>>>>>> Jun 23, 2016 6:44:40 PM org.geoserver.importer.rest.TaskResource
>>>>>> handlePost
>>>>>> INFO: Handling POST of multipart/form-data;
>>>>>> boundary=----------ThIs_Is_tHe_bouNdaRY_$
>>>>>> 23 Jun 18:44:40 WARN [geoserver.security] - Could not find factory
>>>>>> for store : DataStoreInfoImpl[datastore]. Unable to encrypt connection
>>>>>> parameters.
>>>>>> 23 Jun 18:44:40 INFO [org.geoserver] - Loaded store 'datastore',
>>>>>> enabled
>>>>>> 23 Jun 18:44:40 INFO [geoserver.importer] - begining import
>>>>>> 23 Jun 18:44:40 ERROR [geoserver.rest] - No such layer: West_Highway
>>>>>> org.geoserver.rest.RestletException
>>>>>> at
>>>>>> org.geoserver.catalog.rest.LayerFinder.findTarget(LayerFinder.java:39)
>>>>>> at org.restlet.Finder.handle(Finder.java:268)
>>>>>> at
>>>>>> org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
>>>>>> at org.restlet.Filter.doHandle(Filter.java:105)
>>>>>> at org.restlet.Filter.handle(Filter.java:134)
>>>>>> at org.restlet.Router.handle(Router.java:444)
>>>>>> at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
>>>>>> at
>>>>>> com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
>>>>>> at
>>>>>> org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
>>>>>> at
>>>>>> org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
>>>>>> at
>>>>>> org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
>>>>>> at
>>>>>> org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
>>>>>> at
>>>>>> org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
>>>>>> at
>>>>>> org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
>>>>>> at
>>>>>> org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
>>>>>> at
>>>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
>>>>>> at
>>>>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>>>>>> at
>>>>>> org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
>>>>>> at
>>>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>>>>>> at
>>>>>> at
>>>>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
>>>>>> at
>>>>>> org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
>>>>>> at
>>>>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
>>>>>> at
>>>>>> org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
>>>>>> at
>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>>>>> at
>>>>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
>>>>>> at
>>>>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
>>>>>> at
>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>>>>> at
>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
>>>>>> at
>>>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>>>>>> at
>>>>>> at
>>>>>> org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
>>>>>> at
>>>>>> at
>>>>>> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:111)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>>>>> at
>>>>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>>>>>> at
>>>>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
>>>>>> at
>>>>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>>>> at
>>>>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>>>>>> at
>>>>>> at
>>>>>> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
>>>>>> at
>>>>>> at
>>>>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>>>>>> at
>>>>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>>>>>> at
>>>>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>>>>>> at
>>>>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>>>>>> at
>>>>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>>>>>> at
>>>>>> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>>>>>> at
>>>>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>>>>>> at
>>>>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>>>>>> at
>>>>>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>>>>>> at
>>>>>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>>>>> at
>>>>>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>>>>>> at
>>>>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>>>>> at
>>>>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>>>>> at java.lang.Thread.run(Thread.java:745)
>>>>>> 23 Jun 18:44:40 INFO [geoserver.importer] - load to target took 104
>>>>>> 23 Jun 18:44:45 INFO [org.geoserver] - Loaded feature type 'null',
>>>>>> enabled
>>>>>> 23 Jun 18:44:45 WARN [catalog.impl] - Failed to load actual store for
>>>>>> FeatureTypeInfoImpl[null]
>>>>>> 23 Jun 18:44:45 INFO [catalog.rest] - PUT
>>>>>> FeatureTypedatastore,West_Highway updated metadata only
>>>>>> 23 Jun 18:44:46 INFO [geoserver.wms] -
>>>>>> Request: getServiceInfo
>>>>>> Request: reflect
>>>>>> SldBody = null
>>>>>> ValidateSchema = false
>>>>>> Sld = null
>>>>>> StyleUrl = null
>>>>>> Width = 200
>>>>>> Height = 150
>>>>>> Interpolations = []
>>>>>> StyleFormat = sld
>>>>>> Transparent = false
>>>>>> TilesOrigin = null
>>>>>> Tiled = false
>>>>>> Palette = null
>>>>>> FeatureVersion = null
>>>>>> SRS = null
>>>>>> Styles = [StyleImpl[ name=geonode_West_Highway1]]
>>>>>> Layers = [org.geoserver.wms.MapLayerInfo at 1ee3d97d]
>>>>>> MaxFeatures = null
>>>>>> Crs = null
>>>>>> Bbox = null
>>>>>> RemoteOwsType = null
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> BgColor = java.awt.Color[r=255,g=255,b=255]
>>>>>> Exceptions = SE_XML
>>>>>> StyleBody = null
>>>>>> SldVersion = null
>>>>>> StyleVersion = null
>>>>>> ScaleMethod = null
>>>>>> Format = image/png8
>>>>>> Buffer = 0
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BaseUrl = http://sling.gosl.gov.lc:8080/geoserver/
>>>>>> RawKvp = {FORMAT=image/png8, HEIGHT=150, LAYERS=geonode:West_Highway,
>>>>>> WIDTH=200}
>>>>>> RequestCharset = UTF-8
>>>>>> Version = null
>>>>>> Request = GetMap
>>>>>> Mobile: 719-2248
>>>>>> Work: 468-4434
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160624/5e315a28/attachment-0001.html>
More information about the geonode-devel mailing list
