[GeoNode-devel] GeoNode doesn't recognize GeoServer
Simone Dalmasso simone.dalmasso at gmail.com
Thu Mar 24 02:06:01 PDT 2016
Forgot to mention,
the geonode admin panel is just for specific admin tasks. You should use
the normal site to work with it. http://localhost
2016-03-24 10:04 GMT+01:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi,
> geoserver is part of the geonode installation because is customised to
> respect the geonode permissions. The way they work together is that geonode
> uses geoserver to publish spatial data in OGC formats.
> The geonode services are for external OGC services and not the local
> geoserver.
> To check that everything works, just upload a layer in geonode, if it's
> displayed correctly and shouws up in the maps the it's ok. Styles are
> created upon layer upload.
> hope this helps
> 2016-03-24 9:44 GMT+01:00 Haertel, Michael (IITA) <M.Haertel at cgiar.org>:
>> Hello list,
>> I unfortunately seem to have run into a general problem for which I
>> couldn’t find any support on the official pages. I followed the
>> installation instructions from the GeoNode homepage but after the
>> installation it seems that GeoServer and GeoNode are completely
>> disconnected from each other.
>> Both packages have been installed correctly and I can log in to GeoNode
>> admin page and GeoServer Admin page. My expectation was that for example
>> the default styles from GeoServer would be exposed and visible in GeoNodes
>> Style configuration panel. And if I click on
>> http://localhost/admin/services/service I expected GeoNode to find the
>> local GeoServer installation but “Auto-Detect” and “Paired WMS/WFS/WCS”
>> services show no entries.
>> It seems that some configuration step is missing. The only information I
>> found was that I needed to add the following lines to the geoservers
>> web.xml:
>>     <display-name>GeoServer</display-name>
>>       <context-param>
>>           <param-name>GEONODE_BASE_URL</param-name>
>>           <param-value>http://localhost/</param-value>
>>       </context-param>
>>       <context-param>
>>     <param-name>serviceStrategy</param-name>
>> But that didn’t solve anything.
>> Can somebody tell me what I have to do in order to marry these two
>> products? Or do I have wrong expectations?
>> Thank you very much,
>> Michael
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160324/666fceee/attachment.html>
More information about the geonode-devel mailing list
