[GeoNode-devel] GeoNode doesn't recognize GeoServer
Simone Dalmasso simone.dalmasso at gmail.com
Thu Mar 24 02:17:21 PDT 2016
Well,
geonode doesn't ask for a style. It creates one based on the default style
geoserver has. There's no need for a new style, if you have then you can
add it but is not mandatory.
2016-03-24 10:13 GMT+01:00 Haertel, Michael (IITA) <M.Haertel at cgiar.org>:
> Hello Simone,
> Thank you very much for your fast reply but if I upload a layer GeoNode
> asks me to select a style (That was the only reason why I actually wondered
> whether GeoNode and GeoServer know each other). And since the layers are
> served/visualized through GeoServer I expected to find the default styles
> from GeoServer as an option to choose from when I add a layer to GeoNode.
> So that means that I need to copy and paste the SLD from GeoServer to
> GeoNode again?
> But I will try if the visualization works, thanks for the hint.
> Regards,
> *Michael Haertel*
> *GIS & Database Expert*
> *International Institute of Tropical Agriculture (IITA, **www.iita.org*
> <http://../../../AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/FGKNP1ID/www.iita.org>
> Headquarters and West Africa Hub
> PMB 5320, Oyo Road, Ibadan 200001, Oyo State, Nigeria
> International Mailing Address: IITA Limited, Part 7th Floor, Grosvenor
> House, 125 High Street, Croydon, Surrey, CR0 9XP
> Tel: +234 2 7517472  |  USA Tel: +1 201 6336094  |  Fax: +44 208 7113786
> IITA is a member of the CGIAR Consortium (www.cgiar.org
> <http://../../../AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/FGKNP1ID/www.cgiar.org>
> *From:* Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> *Sent:* Thursday, March 24, 2016 10:06 AM
> *To:* Haertel, Michael (IITA)
> *Cc:* geonode-devel at lists.osgeo.org
> *Subject:* Re: [GeoNode-devel] GeoNode doesn't recognize GeoServer
> Forgot to mention,
> the geonode admin panel is just for specific admin tasks. You should use
> the normal site to work with it. http://localhost
> 2016-03-24 10:04 GMT+01:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi,
> geoserver is part of the geonode installation because is customised to
> respect the geonode permissions. The way they work together is that geonode
> uses geoserver to publish spatial data in OGC formats.
> The geonode services are for external OGC services and not the local
> geoserver.
> To check that everything works, just upload a layer in geonode, if it's
> displayed correctly and shouws up in the maps the it's ok. Styles are
> created upon layer upload.
> hope this helps
> 2016-03-24 9:44 GMT+01:00 Haertel, Michael (IITA) <M.Haertel at cgiar.org>:
> Hello list,
> I unfortunately seem to have run into a general problem for which I
> couldn’t find any support on the official pages. I followed the
> installation instructions from the GeoNode homepage but after the
> installation it seems that GeoServer and GeoNode are completely
> disconnected from each other.
> Both packages have been installed correctly and I can log in to GeoNode
> admin page and GeoServer Admin page. My expectation was that for example
> the default styles from GeoServer would be exposed and visible in GeoNodes
> Style configuration panel. And if I click on
> http://localhost/admin/services/service I expected GeoNode to find the
> local GeoServer installation but “Auto-Detect” and “Paired WMS/WFS/WCS”
> services show no entries.
> It seems that some configuration step is missing. The only information I
> found was that I needed to add the following lines to the geoservers
> web.xml:
>     <display-name>GeoServer</display-name>
>       <context-param>
>           <param-name>GEONODE_BASE_URL</param-name>
>           <param-value>http://localhost/</param-value>
>       </context-param>
>       <context-param>
>     <param-name>serviceStrategy</param-name>
> But that didn’t solve anything.
> Can somebody tell me what I have to do in order to marry these two
> products? Or do I have wrong expectations?
> Thank you very much,
> Michael
> geonode-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160324/8cd28a39/attachment-0001.html>
More information about the geonode-devel mailing list
