[GeoNode-devel] Getting my django app to save to postgis instead of the default database...
Dave Kennewell davekennewell at gmail.com
Mon May 9 10:01:54 PDT 2016
Hi all,
I have a django app that harvests latitude and longitude as float numbers,
together with some text, and stores them in a model. After syncdb, this
happily writes to my "geonode" default database.
But I want to plot this data in geoserver, and show it as a layer in
geonode. So (I assume) I need to get the harvested data into the
"geonode_data" postgis database.
When I look into the django documentation for multiple databases
<https://docs.djangoproject.com/en/1.7/topics/db/multi-db/#defining-your-databases>,
it suggests I use DATABASE_ROUTERS to achieve this. Sounds reasonable.
But when I search the geonode codebase for DATABASE_ROUTERS there is nothing
going on
<https://github.com/GeoNode/geonode/search?utf8=%E2%9C%93&q=DATABASE_ROUTERS>
Is it correct that the only way data gets into a standard geonode datastore
is directly via the upload app, and not via any models?
Before I go down the DATABASE_ROUTERS rabbithole, I wanted to check if this
is the correct way to get model data into the datastore, or am I missing
something?
Thanks for any help
Dave
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160509/b249dbd5/attachment.html>
More information about the geonode-devel mailing list
