[GeoNode-devel] Setting up Geosites with custom Geonode as master
Carlo Santos santos.carlo.a at gmail.com
Wed May 18 01:09:14 PDT 2016
Will using paver still work?
On Wed, May 18, 2016 at 3:59 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> No you can use your custom geonode, if you customised it by forking the
> geonode code then the only quick way would be to use it as a base for all
> sites. Otherwise you have to extract the customisations and port them in a
> geonode-project that you will use a s a site-specific folder.
> 2016-05-18 9:57 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>> Hi Simone,
>> Thank you very much for the prompt response. Do we just put our custom
>> Geonode inside this template folder, including the additional apps we
>> created? Do we just put our custom Geonode under the master directory so it
>> will be used as the master website? Do I still have to install the Geonode
>> pip package?
>> On Wed, May 18, 2016 at 3:28 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi Carlos,
>>> you can follow the docs here
>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites.
>>> Basically you have to create a folder from this template
>>> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites/site_template for
>>> each geosite and assign it to the correct site. There is a command that
>>> should help you in creating both the entries in the db and the skeleton of
>>> the site folder
>>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/geosites/management/commands/addsite.py
>>> Once you enable geosites, users and resources will belong to the site
>>> where they have been created or they have been assigned from the admin
>>> panel.
>>> 2016-05-18 9:03 GMT+02:00 Carlo Santos <santos.carlo.a at gmail.com>:
>>>> Hi all,
>>>> I am Carlo Santos from UP-PhilLiDAR1 project and we're in the process
>>>> of developing our custom version of Geonode. We're also looking into using
>>>> Geosites.
>>>> My question is, how do we setup Geosites using our custom Geonode (we
>>>> call it LiPAD)? We followed these instructions
>>>> <http://docs.geonode.org/en/master/tutorials/devel/devel_env/index.html>
>>>> in setting up our custom Geonode. From this point, what steps do we have to
>>>> take to utilize Geosites?
>>>> Thank you very much.
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160518/3587ba20/attachment.html>
More information about the geonode-devel mailing list
