[GeoNode-devel] GeoServer version 2.8.x+ ?
Simone Dalmasso simone.dalmasso at gmail.com
Tue May 31 05:25:19 PDT 2016
Ciao Alessio,
+1 for me.
Thanks
2016-05-31 10:08 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Dear all,
> while the Backup & Restore stuff for GeoServer is moving towards the end
> of development
> (https://github.com/geosolutions-it/geoserver/tree/backup_restore)
> I would like to propose here an update of the GeoServer version on GeoNode
> master branch too.
> GeoServer is currently at version 2.10 while GeoNode is still using the
> old 2.7 one.
> Consider also that in few days we plan to start working on an heavy
> refactoring of the Authorization & Authentication subsystem of
> GeoNode/GeoServer.
> The new GeoServer versions not only have a lot of new features but also
> bug-fixes, performance improvements and some heavy refactoring of the code
> base which allows GeoServer to work much better and be quite versatile.
> I guess we should start thinking to move at least at version 2.8.x of
> GeoServer if not a newest one.
> I volunteer to update the security plugins if the community agrees on the
> version update.
> Please let me know what are your thoughts about this topic.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160531/47a356f7/attachment.html>
More information about the geonode-devel mailing list
