[GeoNode-devel] [GeoNode-users] Changes to local_settings.py ignored [Windows, Apache]
Sara Safavi ssafavi at boundlessgeo.com
Wed Nov 2 14:22:08 PDT 2016
*(minus geonode-users, as bikeshed colors are Serious Dev Business)*
+1 Jeff, re: just edit existing docs. When did Sphinx stop being "modern",
anyway?
On Wed, Nov 2, 2016 at 4:13 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> How about instead of changing the method, someone just sit down and write
> up the changes to the docs necessary. We have a management commands page in
> the docs, its just horribly out of date. The easiest way to change that is
> to just to edit the docs.
> On Wed, Nov 2, 2016 at 11:01 AM, Patrick Dufour <pjdufour.dev at gmail.com>
> wrote:
>> On the first day of the Summit, we should decide on a new more moden
>> method for documentation and whiteboard a new UX flow for geonode.org.
>> I can definitely see us having a "management commands" section of the
>> website.
>> Regards,
>> Patrick Dufour
>> On Nov 2, 2016 1:11 PM, "Francesco Bartoli" <xbartolone at gmail.com> wrote:
>>> Surely, maybe we can handle that during the sprint at the latest
>>> Cheers,
>>> Francesco
>>> Sent from Nylas N1
>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-644a5635-880d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>,
>>> the extensible, open source mail client.
>>> On nov 2 2016, at 1:07 pm, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Hi Francesco,
>>>> good catch. Those commands are not documented on the official GeoNode
>>>> documentation (as far as I can see).
>>>> It would be good to have them documented.
>>>> I'll try to find some time to test them and improve the documentation.
>>>> I have no much time in these days though, so if someone would like to do
>>>> that in the meantime it will be very welcomed.
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> GeoServer Professional Services from the experts!
>>>> Visit http://goo.gl/it488V
>>>> <http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=> for
>>>> more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A
>>>> 55054  Massarosa (LU)
>>>> Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> <http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>> http://twitter.com/geosolutions_it
>>>> <http://twitter.com/geosolutions_it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>> principi dettati dal D.Lgs. 196/2003.
>>>> The information in this message and/or attachments, is intended solely
>>>> for the attention and use of the named addressee(s) and may be confidential
>>>> or proprietary in nature or covered by the provisions of privacy act
>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>> strictly forbidden except previous formal approval of the named
>>>> addressee(s). If you are not the intended recipient, please contact
>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>> information in this message that has been received in error. The sender
>>>> does not give any warranty or accept liability as the content, accuracy or
>>>> completeness of sent messages and accepts no responsibility  for changes
>>>> made after they were sent or for other risks which arise as a result of
>>>> e-mail transmission, viruses, etc.
>>>> On Wed, Nov 2, 2016 at 1:02 PM, Francesco Bartoli <xbartolone at gmail.com
>>>> > wrote:
>>>> Hi Alessio,
>>>> I think the geonode updatemaplayerip [1] might be of help
>>>> Ciao,
>>>> Francesco
>>>> [1] https://github.com/GeoNode/geonode/blob/master/geonode/m
>>>> aps/management/commands/updatemaplayerip.py
>>>> <https://github.com/GeoNode/geonode/blob/master/geonode/maps/management/commands/updatemaplayerip.py&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>> Sent from Nylas N1
>>>> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-56e8c7e4-998d/0?redirect=https%3A%2F%2Fnylas.com%2Fn1%3Fref%3Dn1&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>,
>>>> On nov 2 2016, at 11:49 am, Alessio Fabiani <
>>>> Hello Nicolai,
>>>> I'm going to maintain the discussion on the mailing list so that it can
>>>> be useful for other users too in the future.
>>>> The problem should be related only to the maps. I'm currently not aware
>>>> of a quick command to do this. At this point you have two options:
>>>> 1. Delete only the old maps and rebuild them from scratch.
>>>> 2. Manually update the GeoServer ip address on the database -> main
>>>> geonode database, table "maps_maplayer"
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> <http://goo.gl/it488V&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>> for more information.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> <http://www.geo-solutions.it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>> <http://twitter.com/geosolutions_it&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>> On Wed, Nov 2, 2016 at 10:15 AM, Nicolai Cryer <nkcryer at gmail.com>
>>>> wrote:
>>>> Dear Alessio,
>>>> Thank you so much for your reply, this is really driving me nuts :)
>>>> I just tested it out, and you were spot on - it's only the old maps
>>>> that have this issue. New maps created after changing the URL work
>>>> perfectly. THANK YOU!!! This is such a relief.
>>>> Do you know if there's any way to update the configuration in the
>>>> database? Or should I re-upload all the data?
>>>> 2016-11-02 9:41 GMT+01:00 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>:
>>>> Dear Nicolai,
>>>> is the problem related to the new layers also or just the old ones? Can
>>>> you please describe exactly your test-case?
>>>> The thing is... if you are trying to expose your saved maps, consider
>>>> that the configuration is stored on the database. Therefore if you created
>>>> those maps with the old ip most probably the configuration still has the
>>>> latter recored on the DB.
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> On Tue, Nov 1, 2016 at 3:29 PM, Nicolai Cryer <nkcryer at gmail.com>
>>>> wrote:
>>>> Hi,
>>>> We're trying to open our Geonode installation to the public, and have
>>>> done the necessary DNS stuff. As such, our Geonode is able to serve static
>>>> files (html etc.) to outside the internal network, but the url for WMS
>>>> services etc. still seems to be configured to the localhost.
>>>> As such, users can view the Geonode front-end but cannot be served
>>>> WMS/WFS content from our geoserver (these show up as bad tiles in
>>>> geoexplorer).
>>>> I tried to solve this by editing local_settings.py in
>>>> C:\GeoNode-2.4.x\geonode-2.4.x\geonode, specifically the
>>>> "PUBLIC_LOCATION" key in the OGC dictionary.
>>>> The big problem is that no matter what I change in settings.py or
>>>> local_settings.py, how many times I restart Apache/Tomcat/the whole server,
>>>> delete .pyc files to be regenerated etc., the changes are never reflected
>>>> in the actual OGC configuration. I don't understand where the problem lies!
>>>> I've even attempted to delete settings.py without incident, so it's
>>>> like the files are cached somewhere (perhaps in the bowels of Apache?)
>>>> I would be most grateful for any ideas, because I've almost exhausted
>>>> the list of buttons to push :/
>>>> Best,
>>>> Nicolai
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>>>> <http://lists.osgeo.org/mailman/listinfo/geonode-users&r=Z2Vvbm9kZS11c2Vyc0BsaXN0cy5vc2dlby5vcmc=>
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161102/8892ac82/attachment-0001.html>
More information about the geonode-devel mailing list
